Solving a Pool Leak: Calculating Inches Lost Per Hour
  • Context: High School
  • Thread starter Thread starter xowe
    Lost Per
This discussion focuses on calculating the rate of water loss in a pool due to a leak, based on two time periods: when the pump is on and when it is off. The calculations reveal that while the pump is operational, the effective water loss is 0.147 inches per hour, whereas when the pump is off, the leak accounts for a loss of 0.24 inches per hour. Additionally, the average water loss over the entire observation period of 22 hours is determined to be 0.142 inches per hour. These calculations are essential for accurately assessing pool maintenance needs.
  • Understanding of basic arithmetic operations (addition, division).
  • Knowledge of time conversion (hours and minutes).
  • Familiarity with the concept of flow rates (inches lost per hour).
  • Basic principles of pool maintenance and water circulation.
  • Research methods for detecting and repairing pool leaks.
  • Learn about the impact of water chemistry on pool maintenance.
  • Explore advanced calculations for flow rates in fluid dynamics.
  • Investigate tools for monitoring water levels and flow rates in pools.
Pool owners, maintenance professionals, and anyone involved in pool management or repair who needs to understand water loss calculations and leak detection methods.
xowe
Hello, again. I have a question problem, fairly simple, that I have most likely done wrong. It is about a pool leak.
When the pools water pump is on, from 3:50pm to 10:10am the pool lost 2.25in.
When the pump was turned off from 10:10am, to 1:50pm, it lost 7/8 in. They want to know how many inches are lost every hour. Here's how I did it.
(When water to the pools pumpe is on, from 3:50pm to 10:10am the pool lost 2.25in.)
3:50-10:10= 7hr. 2.25 divided by 7 right? And the same with the other?...xowe
It seems to me a lot easier than you make it.
First, from 3:50 pm to 10:10 am is NOT 7 hours: it is 18 hours and 20 minutes.
From 3:50pm to 10:10am the pump is on (Am I to assume that the pump is actually pumping water into the pool and not just recirculating it?- otherwise the pump is really irrelevant.) so there are two reasons for the level of water to change: change= I- O where "I" is the water pumped in (in "inches per hour") and O is the water flowing out because of the leak (also in "inches per hour")- you have
I- O= 2.25in/18.33 hrs= 0.147 in/hr. From 10:10 am to 1:50 pm, a period of 3 hours and 40 min (= 3.67 hrs) the pump was turned off so the only reason for the change in height, 7/8 in, is the leak itself:
O= (7/8 in)/(3.67 hr)= .24 in/hr.
"They want to know how many inches are lost every hour." I assume those two numbers are the answers you want.
Another possibility is that they want the average over the whole time period. To do that you would not that there was a total of
2.25+ 7/8= 2.25+ 0.875= 3.125 inches in a total of 22 hours. The average rate of drop is 3.125/22= 0.142 in/hour.
  • · Replies 30 ·
