| New Reply |
soft landiing an asteroid at the south pole |
Share Thread | Thread Tools |
| Oct12-11, 08:55 AM | #1 |
can a small nickel/iron asteroid brought near Earth (matching its solar orbital velocity) and soft landed at the south pole where Earth's rotation is not an issue?
| Oct12-11, 09:15 AM | #2 |
Mentor
The Earth's rotation is not an issue, the Earth's gravity is. Because of that anything that's near enough to feel its gravitational pull is going to plummet down. Considering the south pole is where so much water is kept I doubt dropping an asteroid at terminal velocity on it would do us any favours.
| Oct18-11, 06:05 AM | #3 |
Unless you hold it back somehow, that asteroid will be going at least 11km/s by the time it gets near the earth. Earth's rotation or not, that's going to do some damage.
| Oct18-11, 09:50 AM | #4 |
ok - so the asteroid free falls to its terminal velocity - remember, it is not in orbit but starting from rest. Could a system of parachutes slow it down enough to let it crash land (remember, we don't care if it is damaged.) 100 meters/sec would not do much damage on the south pole.
| Oct18-11, 10:16 AM | #5 |
Mentor
| Oct18-11, 03:45 PM | #6 |
The asteroid in question is not an ELE sized rock but a carefully selected nickel/iron
asteroid as big as a house. Since it is starting from rest and not going 17,000 mph, the use of steerable parachutes is feasible. Remember, Antarctica is a continent so there is lots of places to land. A house sized asteroid (15 by 15 by 15 or 1000 cubic meters would weigh 3375 *(450 lbs/cubic foot) = 1518750 pounds. Now that's a lot, but multiple drogue parachutes could probably slow its descent. If not, we would select a smaller asteroid, or use solid rocket motors to slow it down. An Asteroid One one tenth that size weighing 700,000 pounds would be worth 700,000*5.00/lb =3,500,000 dollars (that buys a LOT of parachutes) |
| Oct18-11, 04:01 PM | #7 |
Mentor
Ok, if you are proposing an asteroid that small there are a few more considerations;
* Value of iron in dollars per tonne (times the amounts worked out) ** Value of nickel in dollars per tonne (times the amounts worked out) |
| Oct18-11, 05:16 PM | #8 |
Just as a ballpark figure, on the Kennedy Space Center's FAQ section, they say it costs $450 million for a space shuttle mission. You would need a pretty big asteroid to cover that.
| Oct19-11, 01:59 AM | #9 |
| Oct19-11, 03:40 PM | #10 |
Assuming we can land it without burning it up, it is still an immense undertaking. I think the
following steps would be required: - getting the stuff for the 'asteroid mission' up there at a minimum cost. Perhaps an air breathing, tail first reusable craft to get the stuff into low Earth orbit. - Can we use solar sails to get a robot to the asteroid belt to find 'candidates' of the right size and composition? - Before going further, the candidate will have to have steering rockets at the end of tow cables installed as well as hooks for sails and parachutes. - Can we sling shot the asteroid around Jupiter under sail to direct it back to Earth All in all a very expensive mission (especially the first one.) It also may be possible to impact the asteroid on the moon and send the cut up pieces back to earth by solar powered linear accelerators. Those asteroids could be big enough to be economically more feasible. |
| Oct20-11, 06:04 AM | #11 |
Mentor
This really does seem horrifically expensive. This plan sounds like it would cost 10s-100s of billions for R&D and running costs! That means that for the 1000m3 asteroid you suggested before the amount of money you would get from the sale would be ~0.001% of the cost of getting it. All in all this seems like far too much effort for little benefit. Apart from the fact that the back-of-the-envelope value I gave above as to how much you could sell an asteroid for injecting so many resources into the world economy would significantly reduce the value. Supply and demand, if you get a huge asteroid of iron the cost of iron will plummet. You might as well spend that 10s-100s of billions on new mines, recycling technologies and re-designing products to run without costly/scarce resources. The only way I can see this as being a good idea was if the mining were as a by product of another project. For example, we knock a couple of asteroids into orbit to construct a space elevator. |
| Oct20-11, 07:48 AM | #12 |
Mentor
Space mining might eventually become a going venture, but never for something as common as iron, or even something like nickel which is about 20 times less common than iron (and hence about 20 times more expensive). It might be worthwhile for those common elements if the mined material is used to manufacture items in space, never bring them back to Earth. Mining things in space and bringing the refined material back to Earth might be worthwhile, but only for substances such as gold, iridium, and tritium that are several orders of magnitude more valuable than iron and nickel. And then it will be treated as the precious (and small) cargo that it is. It will not be dropped like a rock on Antarctica. |
| Oct20-11, 10:08 AM | #13 |
First, I would like to thank everybody on this thread for their input. I think we can put the Earth landing to rest as being impractical. However, there are 3 more logical targets out there - the moon, Mars, and Earth orbit where the nickel and iron would be very valuable. Someone is already thinking of mining lunar water and selling it in low Earth orbit (Shakleton mission.) So getting materials for space exploration from non-terrestrial sources is a very practical mission.
| Oct20-11, 11:30 AM | #14 |
Mentor
As for the moon water thing that leaves me gobsmacked. There is no way that regular Earth-to-Moon and back again mass transport as well as water mining in what is essentially a desert would be cheaper than a desalination station on the coast. |
| Oct21-11, 04:56 AM | #15 |
Mentor
| Oct21-11, 09:13 AM | #16 |
Mentor
D H I didn't realise we'd swapped the conversation onto in situ resource allocation. Considering that's a world away from landing an asteroid on Earth for mining I'd say this thread is going slightly off topic.
| Oct23-11, 07:29 AM | #17 |
Asteroid mining
The figures given in this link makes me think that asteroid mining can become a reality ... probably by the 2nd half of this century or by the beginning of the 22nd century. |
| New Reply |
| Tags |
| asteroid |
| Thread Tools | |
Similar Threads for: soft landiing an asteroid at the south pole
| North pole and south pole of a magnet. | General Physics | 10 | ||
| north and south pole in an electromagnet | General Physics | 11 | ||
| Google earth image of the South pole? | General Discussion | 11 | ||
| North/South pole identifier | Electrical Engineering | 1 | ||
| Wire does a loop of wire create a norh pole and a south pole | General Physics | 2 | ||
