How can a metric connection have torsion?
The discussion revolves around the concept of metric connections in the context of torsion, particularly focusing on the Levi-Civita connection and its properties. Participants explore the implications of torsion in Einstein-Cartan theory and the relationship between geodesics defined by different types of connections.
  • Some participants question how a metric connection can have torsion if it is defined such that the covariant derivative of the metric is zero, suggesting that this condition should lead to the Christoffel symbols, which are symmetric.
  • Others reference Einstein-Cartan theory, proposing that it must utilize a non-symmetric metric connection to preserve the equivalence principle, indicating that such connections can exist.
  • One participant asserts that the geodesics remain the same for all metric connections, regardless of torsion, but notes that parallel transport along these geodesics may involve additional twisting terms.
  • Another participant discusses the relationship between the cancellation of the nonmetricity tensor and the symmetric components of the connection, linking this to the torsion tensor through the commutator of covariant derivatives.
  • There is a discussion about the derivation of the Christoffel symbols from the metric, with some participants expressing confusion about the presence of antisymmetric terms that may not be explicitly mentioned in standard derivations.
  • One participant clarifies that while extremizing the length functional gives the coefficients in the geodesic equation, it does not account for the antisymmetric part of the connection, emphasizing that geodesics can be defined without a metric.
Participants express differing views on the relationship between metric connections, torsion, and geodesics. There is no consensus on whether the presence of torsion affects the geodesics defined by the connection or the implications of Einstein-Cartan theory.
Some discussions involve assumptions about the nature of connections and the definitions of geodesics, which may not be universally accepted or clearly defined across all contexts.
This discussion may be of interest to those studying general relativity, differential geometry, or theoretical physics, particularly in relation to the properties of connections and geodesics.
Matterwave
Hi, I'm reading this wikipedia article on the metric connection, and it says that the Levi-Civita connection is a metric connection without torsion. If the metric connection is defined so that the covariant derivative of the metric is 0, how can there be torsion? Doesn't this condition force the connection to be the Christoffel symbols and therefore there is no torsion?
See http://en.wikipedia.org/wiki/Einstein–-Cartan_theory
I just realized that Einstein-Cartan theory must use a non-symmetric metric connection (if it is to at least preserve the equivalence principle), so apparently these things can exist.
Do we take the torsion free connection in GR because these are the ones that give us metric geodesics which coincide with the affine geodesics?
In Einstein-Cartan theory, are the geodesics defined by the connection it uses different than the geodesics defined by the metric (in the sense of maximizing the interval)?
The geodesics are the same for all metric connections, whether they have torsion or not. The only difference is that parallel transport along these geodesics has extra twisting terms.
In general, for a class of connections all differing only by their torsions, the geodesics will be the same. You can see this easily in the geodesic equation
[tex]\frac{d^2 x^\mu}{d \lambda^2} + \Gamma^\mu_{\nu\rho} \frac{d x^\nu}{d \lambda} \frac{d x^\rho}{d \lambda} = 0[/tex]
Notice that the connection coefficients get symmetrized by contracting with the velocity vector. So the geodesic equation doesn't care about the antisymmetric part (i.e. the torsion).
The cancellation of the nonmetricity tensor fixes only the symmetric components of the connection, while the antisymmetric ones are linked to the torsion tensor by the computation of the commutator of covariant derivatives of a vector field.
See also the discussion in the thread referenced by my blog entry below including the books mentioned there.
https://www.physicsforums.com/blog.php?b=2565
But I thought that one could prove, from maximizing the interval that the geodesic equation that the Christoffel symbols are defined from the metric:
[tex]\Gamma^i_{jk}=\frac{1}{2} g^{l i}\left(\frac{\partial g_{lk}}{\partial x^{j}}+\frac{\partial g_{lj}}{\partial x^{k}}-\frac{\partial g_{jk}}{\partial x^{l}}\right)[/tex]
This is obviously symmetric, no? Is it that hidden in here is an anti-symmetric term that the books don't usually mention?
EDIT: I have no idea why latex is not rendering the first partial sign...
The vBulletin software that runs this forum doesn't understand [itex]\LaTeX[/itex] (which is handled by an add-on), thinks you've typed a very long word that will mess up line-wrapping, so inserts an extra space which upsets the TEX.
The fix is for you to insert spaces into your TEX at reasonably frequent intervals in places where it doesn't matter, i.e. between symbols.
[tex]\Gamma^i_{jk}=\frac{1}{2}g^{li} \left( \frac{\partial g_{lk}}{\partial x^{j}} + \frac{\partial g_{lj}}{\partial x^{k}} - \frac{\partial g_{jk}}{\partial x^{l}} \right)[/tex]
Not quite. Assuming a metric-compatible connection, then extremizing the length functional will give you the coefficients that appear in the geodesic equation. It will not, as you have pointed out, give you the antisymmetric part of [itex]\Gamma^\mu_{\nu\rho}[/itex].
Note that for non-metric connections, geodesics do not extremize the length functional. In fact, one can have the notion of a "connection" without even having a metric at all. Extremizing the length functional is not the most fundamental way to define what a geodesic is. The most fundamental way is to say that geodesics are autoparallels; that is, they parallel-transport their own tangent vector along themselves. This definition applies for any connection, metric-compatible or otherwise, including when you don't have a metric.
Ok, that makes sense. Thanks!
My fellow forum users, I learned so much from this thread just by lurking... thank you, my god...
  • · Replies 62 ·
  • · Replies 19 ·
  • · Replies 24 ·
