Determing Resistance of metal with temperature coefficient of resistance
The discussion focuses on determining the resistance of a metal using the temperature coefficient of resistance, alpha. The equations provided are R_T = R_273(1+alpha(T)) and R_T = R_0(1+alpha(T)). The user is advised to rearrange the equations to R_T = R_0(1+alpha(T - T0)) for accurate calculations. It is crucial to perform linear regression on the data while ensuring that the temperature remains within the linear region to avoid non-linear behavior at lower temperatures.
  • Understanding of resistance and temperature relationships in metals
  • Familiarity with the concept of temperature coefficient of resistance (alpha)
  • Knowledge of linear regression techniques
  • Ability to interpret experimental data and graphs
  • Research how to calculate the temperature coefficient of resistance (alpha) from experimental data
  • Learn about linear regression methods for data analysis
  • Explore the effects of temperature on metal resistance in detail
  • Study the non-linear behavior of metals at low temperatures
Students in physics or engineering, researchers conducting experiments on metal properties, and anyone interested in understanding the relationship between temperature and electrical resistance in materials.
eximius
I'm trying to determine R_0 and alpha (temperature coefficient of resistance) from results I obtained through an experiment. We have been given the first equation and been told that R_T is the resistance at temperature T in kelvin. R_273 is the resistance at temperature 273K and alpha is a constant called the temperature coefficient of resistance. I don't know what the material is therefore I have no idea of what alpha should be.
1)R_T = R_273(1+alpha(T))
2)R_T = R_0(1+alpha(T))
I created the attached graph to try and determine alpha through the gradient of the line, but no matter how i try and derive alpha and/or R_0, I simply can't get an answer that's gives valid results for R_T at other temperatures.
First, I think you want to write your equations in the form:
so when T = T0, then R_T = R_0
Then, I would re-arrange your equation into the standard form:
y = mx + b
And you can solve for alpha with linear regression or pick two good end-point. Metals get non-linear at cold temperatures (as your graph shows) so stay in the linear region.
  • · Replies 97 ·
