Definition of a limit of a sequence
The discussion revolves around proving the limit of a sequence using the formal definition of limits. The specific problem involves showing that if the limit of a sequence \( a_n \) approaches 1, then the limit of \( (1 + a_n)^{-1} \) approaches \( \frac{1}{2} \).
  • Participants discuss the implications of the limit definition and how to apply it to the sequence. There are attempts to clarify the relationship between different epsilon values and their significance in the proof. Questions arise about the choice of epsilon and its role in establishing bounds for the sequence.
The discussion is ongoing, with participants providing insights and attempting to clarify the proof structure. Some guidance has been offered regarding the choice of epsilon and its implications, but there is no explicit consensus on the completion of the proof.
Participants express uncertainty regarding the rigorous definitions and the application of limits, indicating a need for deeper understanding of the epsilon-delta framework. There is a time constraint mentioned, as the homework is due soon.
lizarton
Use the definition of a limit to prove that lim [(1+an)-1] = 1/2 if lim an = 1.
([itex]\forall[/itex][itex]\epsilon[/itex]>0)([itex]\exists[/itex]N[itex]\in[/itex]N)(n[itex]\geq[/itex]N [itex]\Rightarrow[/itex]|an-L|<[itex]\epsilon[/itex])
Let [itex]\epsilon[/itex] be arbitrary. Since lim an exists, [itex]\exists[/itex]N[itex]\in[/itex]N such than |an-1|<[itex]\epsilon[/itex]'.
My professor helped me a bit, but once we started comparing two different epsilons, I couldn't follow him anymore. He said to choose [itex]\epsilon[/itex]'< 1/2 since 1/2 < an, but I don't understand why we can say that the sequence is greater than or equal to 1/2 since we only know the value of its limit.
Any help would be appreciated, I've always had a hard time with the rigorous definitions.
Welcome to PF.
Let me try to read his mind.
Since lim an exists, ∃N∈ℕ such than |an-1| < ϵ'.
Letting ϵ' = 1/2, since it is arbitrary, gives: |an-1| < 1/2  → -1/2 < an-1 < 1/2
Therefore, 1/2 < an < 3/2.  It's the 1/2 < an you're interested in.
If an > 1/2, then 2(an + 1) > 3  → [itex]\displaystyle \frac{1}{2(a_n+1)}<\frac{1}{3}[/itex]
That should be handy in working with |(1+an)-1 - 1/2|, when you write that as one fraction with a common denominator.
So then, we have showed that 1/(1+a_n) < epsilon'/3 < epsilon', but is this the end of the proof? I guess my question is, when does the other epsilon come in? or is epsilon' just our other epsilon in disguise? Thank you so much! I could use a mind-reader for this professor :)
Also, if you wouldn't mind--(this homework is due in an hour, so this is more for my understanding)--in general, how do we know how to choose epsilon so that it will give us the result we are looking for? Is there a reason choosing epsilon'=1/2 was particularly useful for this problem?
No, that's not the complete proof.
Let ε' = min(ε, 1/2)
Then you have N∊ℕ such that for n > N, |an-1| < ε' ≤ 1/2
This leads to 1/(2|an+1|) < 1/3.
Also, for n > N, |an-1| < ε' ≤ ε
Put them together, & you get (the desired quantity) < ε/3 < ε​
