Electromagnetic waves and phase difference
The discussion revolves around the phase difference between the electric field (E) and magnetic field (B) in electromagnetic (EM) waves. The original poster expresses confusion regarding the assertion that E and B are in phase, despite their descriptions of phase relationships.
  • Participants explore the nature of phase relationships in EM waves, questioning the original poster's interpretation of phase difference. They discuss the implications of E and B being in phase and how this relates to their graphical representations.
The discussion has seen participants providing clarifications and insights regarding the phase relationship of E and B in EM waves. Some participants have offered explanations to help the original poster understand the concept better, while others have raised questions about the comparison of different wave representations.
There is an ongoing exploration of how to interpret graphical representations of waves, particularly in relation to their phase differences. Participants are also considering the implications of comparing vectors in different orientations.
logearav
Electromagnetic waves contain time varying electric and magnetic field perpendicular to each other and also to path of progression. The phase difference between electric field vector and magnetic field vector is zero
How the phase difference is zero? Because when E is at ∏/2, B is at -∏/2. When phase difference is zero, Both E and B are in phase with each other, which means when E is at zero, B should also be at zero and when E is at ∏, B should also be at ∏. I am confused. Revered members, please help
Why do you say that?
Thanks for the reply. Now I have provided the image for EM wave and also another image --- two coloured curves representing two completely out of phase waves.
Both look similar. Then how can we say EM waves are in phase with each other?
The two illustrations, while looking similar, really have nothing to do with each other.
In the first one, you have two waves of different types which point in perpendicular directions. One is the electric field; the other is the magnetic field. They don't add to together or anything like that. Note that E and B peak at the same time, and they vanish at the same time. They oscillate in phase.
vela,
Now if i assume the coloured curves as a EM wave, Red representing E, and Blue representing B, can i say they are in phase?
E and H are perpendicular. For example, E vibrates in the x direction and H vibrates in the y direction. You can not plot them in the same graph as the left picture in your attachment. There the curves have opposite phases, as one is minimum and the other maximum at the same time.
But E and H can not be compared this way. You can compare vectors by their magnitude, but can not say that the vector (2,0) is larger than (0,-2).
E and H in phase means that both have peak value at the same time and zero at the same time, as Vela pointed out.
ehild
@ehild,
I got it now. Thanks a lot.
@Vela
Thanks for clarifying. I read your post again with inputs from ehild and i got it now. Thanks a lot, Vela, for your reply.
  • · Replies 18 ·
  • · Replies 35 ·
