Trigonometry - half angles problems
The discussion revolves around a trigonometry problem involving half-angle and double-angle formulas. The original poster has expressed cos(2x) in terms of sin(x) and is now attempting to solve the equation cos(x) + 3sin(x/2) = 2, seeking guidance on how to handle the half-angle component.
  • Exploratory, Assumption checking
  • Participants discuss the relationship between full angles and half angles, with some suggesting the use of substitution to simplify the equation. There is a focus on how to eliminate the half-angle term and the potential use of a new variable for clarity.
Participants are actively engaging with the problem, offering suggestions for substitution and exploring the implications of those substitutions. There is a recognition of the need for a refresher on handling half angles, indicating a productive direction in the discussion.
Some participants note the difficulty in framing the problem within the expected format, highlighting the challenge of addressing half-angle concepts in the context of the given equation.
paul18
Previous part of the question I have solved:
Express cos(2x) in terms of sin(x):
I got this answer:
cos(2x)=1-2sin2(x)
Hence or otherwise solve the equation
Double angle formulae:
cos(2x)=cos(2x) - sin(2x)
sin(2x)=2sin(x)cos(x)
So basically I'm doing revision on trig, and I know I've come across this problem before, where you are presented with a full angle and a half angle, but I have failed to find an example. It's something to do with halving a double angle formula I think but I can't even start it. How do I get rid of the half angle? I know I should show an attempt, but I can't even start it off. Just a refresher on how to remove half angles would be great thanks :)
(Yes i have read the rules but this problem is difficult to put into that format properly)
I got this answer:
cos(2x)=1-2sin2(x)
If the first part read cos(2z) in terms of sin(z), what would your answer be? Then substitute z for x/2 in the second question
I got this answer:
cos(2x)=1-2sin2(x)
Note that x = 2 times (x/2). It may be helpful if you substitute another variable, say y, in for x/2. What would x equal? What does this equation:
look like with the substitutions?
cos(2y) + 3sin(y) = 2.
Thanks very much that's what I needed a refresher on :)
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 18 ·
