Can Optical Tweezers Manipulate Conducting Microscopic Particles?
  • Context: Graduate
  • Thread starter Thread starter pjbeierle
    Optical
The discussion centers on the capabilities of optical tweezers in manipulating conducting microscopic particles, contrasting them with dielectric particles. Participants explore the theoretical and practical limitations of optical trapping, particularly regarding size and material properties.
  • One participant questions why optical tweezers are typically associated with dielectric particles and whether conducting particles can also be manipulated, noting that optical trapping can occur at the atomic scale.
  • Another participant explains that dielectric materials behave as electric dipoles in an electromagnetic field, which allows them to be trapped, while conducting particles reflect laser beams, raising uncertainty about the net force on such particles.
  • A participant mentions that there is a lower limit to the size of particles that can be trapped due to diffraction limits and emphasizes the need for particles to be large enough to respond to the electric field gradient.
  • It is noted that smaller metal particles, around 10 nm, have been attempted to be trapped, with the mechanism involving surface plasmons differing from that of dielectric particles.
Participants express varying views on the feasibility of trapping conducting particles, with some acknowledging attempts to trap smaller metal particles while others remain uncertain about the implications of reflection versus refraction in optical trapping.
Limitations include the unclear implications of reflection for conducting particles, the diffraction limit affecting the minimum size for trapping, and the differing mechanisms of trapping for dielectric versus conducting materials.
pjbeierle
it typically states that optical tweezers are used to manipulate dielectric particles or whatnot. Is it also possible to do the same with conducting microscopic particles? what are the limitations besides mass being not too large? obviously optical trapping can be used down to the atomic scale as well (which is why one can make bose-einstein condensates), so I am confused why it is specified as being dielectric.
Welcome to Physics Forums.
A dielectric material behaves as an electric dipole in an electromagnetic field (i.e. the laser beam), due to the electric field inducing a dipole moment in the dielectric. Since an electric dipole is attracted toward the region of highest electric field strength, the laser beam works as an optical tweezers with dielectric particles.
A conducting particle will reflect the laser beam, rather than refract & transmit it. However, it's not clear to me what that will mean in terms of the net force on the particle.
there is lower limit to size of the particle that you can trap with the optical tweezer since the diameter at the focus is diffraction limited. The particle should be big enough to feel the electric field gradient, so that the photon/particle momentum exchange will drive the particle to be trapped highest intensity region of the focus.
Smaller metal particles (of the order of 10 nm) can be trapped. Or at least there were some attempts. I did not follow the work in the field for a few years. The mechanism is different than the one for dielectric particles. It has something to do with excitation of surface plasmons.
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 45 ·
13K
