Spring and Projectile Motion Problem
The discussion focuses on solving a physics problem involving a spring and projectile motion. The participant successfully calculated the time of flight using the formula time = sqrt((-2h)/g) and derived the horizontal velocity as v = d/sqrt((-2h)/g). They then combined the velocity of a spring equation, v = (2πX)/T, with the period T = 2π√(m/k) to determine the spring constant k. Finally, they applied the work done by the spring formula, w = 1/2kx², to complete the problem.
  • Understanding of projectile motion principles
  • Familiarity with Hooke's Law and spring mechanics
  • Knowledge of simple harmonic motion equations
  • Basic algebra and manipulation of physics formulas
  • Study the derivation of projectile motion equations in detail
  • Learn about Hooke's Law and its applications in spring mechanics
  • Explore the relationship between spring constant and oscillation period
  • Investigate energy conservation principles in spring systems
Students in AP Physics, educators teaching mechanics, and anyone interested in understanding the dynamics of springs and projectile motion.
mkcompu
Ok, I need some help getting started with a problem involving a spring and projectile motion.
one end of a spring is attached to a solid wall while the other end just reaches to the edge of a horizontal, frictionless tabletop, which is a distance h above the floor. a block of mass m is placed against the end of the spring and pushed toward the wall until the spring has been compressed a distance x, as shown above. the block is released, follows the trajectory shown, and strikes the floor a horizontal distance d from the edge of the table. air resistance is negligible.
determine expressions for the following quantities in terms of m, x, d, h and g. notes that theses symbols do not include the sprig constant.
a) the time elapsed from the instant the block leaves the table to the instant it strikes the floor
b) the horizontal component of the velocity of the block just before it hits the floor.
c) the work done on the block by the spring.
d) the spring constant
A picture of the problem is attached.
Part A was easy, done with projectile motion. I worked it out to time = sqrt((-2h)/g).
Now I'm stuck on where to start with part B because we are not given a spring constant. I know that just the speed as it leaves the platform needs to be found because there is no acceleration on the x component.
I played around with simple harmonic motion equations but keep getting stuck on the fact that I don't know what K is or the force needed.
And for reference I'm in ap physics b.
Any help to get me started would be greatly appreciated.
Thanks.
Hint: You figured out the time in part a. What horizontal distance did it travel in that time?
Thanks. It was so obvious, I got too caught up in the equations. I never thought I would forget that v=s/t but I just did...Thanks for the reminder.
So I got v=D/sqrt((-2h)/g)
Ok, so then It's a matter of using an equation for velocity of a spring, v=(2piX)/T and combining it with T=2pisqrt(m/k), I can find K [got part D done right there!] and then using w= 1/2kx^2.
Sounds good to me.
  • · Replies 21 ·
