Limits and Continuity of a Piecewise Function
The discussion revolves around determining a value for k that ensures the continuity of a piecewise function at x = 5. The function is defined differently for x equal to 5 and for values approaching 5, involving a square root and a rational expression.
  • Participants discuss the limit of the function as x approaches 5 and its comparison to the function's value at x = 5. There is a focus on the correct application of the definition of continuity and the proper formulation of the function.
The conversation has progressed with participants offering guidance on how to approach the problem, particularly emphasizing the importance of correctly interpreting the function and its limits. There is acknowledgment of a misunderstanding in the original problem statement, which has been clarified.
There was initial confusion regarding the formulation of the function, which was later corrected by the original poster. The discussion also highlights the need for clarity in mathematical expressions to avoid complications in problem-solving.
genevieveb
Find a value for k to make f(x) continuous at 5
f(x)= sqrt(x2-16)-3/(x-5) if x cannot equal 5
3x+k when x=5
none
lim x->5 sqrt((x+4)(x-4))-3/(x-5) * sqrt((x+4)(x-4))+3/sqrt((x+4)(x-4))+3
lim x->5 (x+4)(x-4)-9/(x-5)[sqrt((x+4)(x-4))-3]And that's as far as I got. I'm not sure what my next step should be or if what I did is wrong. I graphed the function and used a program to solve for the limit which is apparently 5/3, but I couldn't come up with that answer. I would really appreciate any help/suggestions. Thanks.
You need to use parentheses to make it clear what you're doing. It looks like what you are doing is finding
[tex]\lim_{x \to 5} \frac{\sqrt{(x+4)(x-4)}-3}{x-5}\cdot \frac{\sqrt{(x+4)(x-4)}+3}{\sqrt{(x+4)(x-4)}+3}[/tex]
My first question to you is, why? I don't see why you have the x-5 in there. Look up the definition of continuity. You should see you're making this problem harder than intended. Or did you not describe f(x) correctly in the beginning of your post?
Sorry! I copied the question wrong the first time. I fixed it. It is all over (x-5) in the first part of the function. Sorry about that.
Compare limx→5f(x) amd f(5) .
Oh, okay. Then you're headed in the right direction. Like SammyS says, calculate the limit and compare it to f(5).
I figured it out, thank you!
  • · Replies 31 ·
  • · Replies 27 ·
