| New Reply |
Diamagnetic Levitation |
Share Thread | Thread Tools |
| Oct15-11, 11:43 PM | #1 |
So I want to levitate....(drum roll please)....A REALLY SMALL WORM!!!
First off, I read that the downward pull on the worm will be gr (gravity times density), so then how would I calculate how powerful my magnet would have to be to balance this force? So thats the mathematical part... Now, what else can I do with this experiment? I want to test stuff, not just levitate a worm (although levitating a worm is still awesome). Any suggestions? Thanks |
| Oct16-11, 08:08 AM | #2 |
I am afraid - levitating even small warm seems impossible without use of the strongest magnets in the world.
Famous Frog of Nijmegen levitated in a field of 16T magnet. Size of the warm doesn't really matter (unless you want to levitate the elephant) - it is water diamagnetism which causes levitation, and as long as the object is smaller than magnet yoke - it makes no difference if it has 1mm or 1cm. To levitate water (or any living creature, built mostly of water) you must create magnetic field gradient bigger than 1400 T2/m http://en.wikipedia.org/wiki/Magnetic_levitation http://www.ru.nl/hfml/research/levitation/diamagnetic/ |
| Oct16-11, 04:42 PM | #3 |
Awww...well what are some easy levitating resources? I know that theres a special type of graphite that works well...any other?
| Oct16-11, 05:18 PM | #4 |
Graphite seems to be easiest one.
But bismuth may work too. Long time ago I used to demonstrate for students levitation with 1T permanent neodymium magnets and a cube 1cmx1cmx1cm or so of metallic bismuth. |
| New Reply |
| Thread Tools | |
Similar Threads for: Diamagnetic Levitation
| simple diamagnetic question | Classical Physics | 2 | ||
| Reference for diamagnetic vs paramagnetic | Atomic, Solid State, Comp. Physics | 4 | ||
| Might This Work? A Diamagnetic Theory | General Physics | 13 | ||
| Fe and paramagnetic/diamagnetic | Atomic, Solid State, Comp. Physics | 0 | ||
| Size of a Diamagnetic | Classical Physics | 1 | ||
