How Do You Calculate the Area Between Curves in Calculus Problems?
  • Thread starter Thread starter buffgilville
The discussion revolves around calculating the area between curves in calculus, specifically focusing on the functions f(x) = x^2 - 5x + 3 and H(x) = -x, as well as two other equations involving y. Participants are exploring methods to find the area bounded by these curves.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss finding intersection points of the curves to determine the limits for integration. There are questions about the nature of H(x) and whether it is an antiderivative. Some participants suggest graphing the functions to visualize the bounded region.
There is ongoing exploration of different approaches to solve the problems, with some participants providing guidance on how to set up the integrals. However, discrepancies in calculated areas indicate that there is no clear consensus on the correct answers, and some participants express confusion over the results.
Participants note that the problem may involve assumptions about the functions and their relationships, and there is mention of potential typos in the original question. The discussion reflects a lack of clarity regarding the expected outcomes, particularly with negative area results.
buffgilville
1) Find the area of the region bounded by the graphs of
f(x) = x^2 - 5x + 3
and
H(x) = -x
Is H(x) an antiderivative? how do I solve this?
2) Find the area of the region bounded by the graphs of
x - y^2 + 2y + 4 = 2
and
2y - 2 - x = 0
so, x = y^2 - 2y - 2 and x = 2y - 2
I, then, substitute the x: y^2 - 2y -2 = 2y -2 and got y^2 - 4y=0
so, y=0,4
then I solve with antiderivatives and got -32/3 but the correct answer is
-16/3
f(x) = x^2 - 5x + 3
and
H(x) = -x
It looks like you're meant to assume that H(x) is just another function, like the quadratic you're given. What you need to do is find out where H(x) = f(x) and then find the areas under H(x) and f(x) between these limits and subtract one from the other. Finding the area under H(x) won't even require integration, as it's a straight line.
1)
Did you draw a diagram so that you could see what was going on? You could simply plug the two functions into your computer or graphing calculator and see what bounded region the question is talking about. But it's not hard to graph it by hand, right?
h(x) = -x --a line passing through the origin with slope -1
The second graph is obviously parabolic, and it's easy to see what it's like by completing the square:
[tex]f(x) = x^2 - 5x + 3 = x^2 - 5x + 25/4 + 3 - 25/4[/tex]
[tex]= (x - 5/2)^2 -13/4[/tex]
So the graph is just that of y = x2 with a vertex shifted 5/2 to the right and 3 1/4 down. Now that you're looking at the graph, you can see that it's bound by h(x) on top and f(x) below. Can you see then that the area will be given by:
[tex]\int_a^b {(h(x) - f(x))}dx[/tex]
But what are these points bounding the region on the left and right, with x-coordinates a and b, respectively? They are the intersection points of the graphs of the two functions! They must satisfy both expressions, so that:
[tex]-x = x^2 - 5x + 3[/tex]
[tex]0 = x^2 - 4x + 3 = (x-3)(x-1)[/tex]
[tex]x = 1, x = 3[/tex]
so we have intersection points (1, -1) and (3, -3)
The area becomes:
[tex]\int_1^3 {(-x - x^2 + 5x -3)}dx[/tex]
[tex]= \int_1^3 {(- x^2 + 4x -3)}dx[/tex]
I get -4/3 by hand, which agrees with the TI-83 answer -1.33333333333333...
Try #2 now
cepheid, I followed what you did and still got -32/3 for #2, but the correct answer is -16/3
Well, I gave it a shot, but really you should post YOUR work from now on. so that people can see what you did and help you along...don't just say..."Oh I did such and such, but it didn't work."
In this case, I'm at a loss, unless there's a typo in the original question. I didn't get -16/3. Here's what I did:
1) Solved for x in terms of y for both functions (it happens to be easier that way in this problem)
2) Plotted the graphs (x vs y) for both functions, and determined which curve formed the lower and upper boundary of the region
3) Equated the expressions for the functions to solve for the intersection points.
That gave me:
[tex]\int_0^4 {(-y^2 + 4y)dy} = \left[-\frac{y^3}{3} + 2y^2\right]_0^4[/tex]
[tex]= -\frac{64}{3} + 32 = -\frac{64}{3} + \frac{96}{3} = \frac{32}{3}[/tex]
According to you, that's not the answer! I don't know what's going on with this problem.
Where did you get the "correct" answer from? Does it bother you that your question asked for an area and this solution is negative? (you might want to check cepheid's anwser for #1 as well)
  • · Replies 40 ·
  • · Replies 22 ·
