Solving for Speed: Roller Coaster at the Top of a Loop
The discussion revolves around determining the speed of a roller coaster car at the top of a loop with a diameter of 46 meters, where the normal force equals the gravitational force. Participants are exploring the dynamics involved in circular motion and the forces acting on the roller coaster at the loop's apex.
  • Participants discuss the balance of forces at the top of the loop and question what forces must be considered. Some express confusion about the application of equations and the significance of the loop's radius in relation to gravitational acceleration.
Some participants have provided guidance on breaking down the problem systematically and identifying relevant equations. There is acknowledgment of differing interpretations regarding the forces acting on the roller coaster, with some clarifying that the normal force and gravitational force do not balance but rather reinforce each other.
Participants note that the diameter of the loop is 46 meters, leading to a radius of 23 meters, which is crucial for calculating centripetal acceleration. There is a discussion about the implications of the normal force being equal to the gravitational force in this context.
SherBear
The normal force equals the magnitude of the gravitational force as a roller coaster car crosses the top of a 46m--diameter loop-the-loop.
What is the car's speed at the top?
the answer is in m/s
I have several equations but I really don't know what to do with them...
the sum of Fr=nr+(Fr)r=n+mg=m(Vtop)^2/r
and n=m(Vtop)^2/r-mg
Vc=SQRTrmg/m=SQRTrg
wc=SQRTg/r
I'm really lost on this one.
For the normal force to equal the gravitational force, what forces must balance?
It looks like you have everything you need to solve the problem. You just need to figure out what pieces fit where. You should break the problem down a bit: What do you want to find? What information are you given/do you already know? And: What information is necessary to find what you want to find?
Write down the answers to these questions, and then look at your equations. Which equations contain the thing you want to find, and in those equations, in which ones can you plug in some information given to you in the problem statement? One of the equations is the one you want to start from. Another is a rearrangement of that, but the rearrangement isn't useful because you've solved for something that you know, not something that you don't know.
Sorry if this seems a bit vague. I'm merely trying to encourage you think about these sorts of problems in a more systematic way without outright giving away the answer, while still trying to help you avoid getting tripped up. Once you take another look at your stuff, if you're still stuck someone will help you out further.
I was able to figure this one out.
Vc=Sqrt 46m (9.8 m/s^2)=
sqrt 450.8=
Vc=21.23 m/s
it was correct
Thank you!
sqrt 450.8=
Vc=21.23 m/s
it was correct
Thank you!
You have the right answer, but I would have preferred to see 23m (19.6 m/s2).
That would indicate you realized that the RADIUS of the loop was only 23 m, and the acceleration at the top of the loop was twice that of gravity.
Please respond if you didn't realize that and I will explain.
Peter
There are no forces balancing! This roller coaster is on the inside of the loop! Gravity and the Normal force are in the same direction - they reinforce or supplement each other rather than balancing.
Peter
Yes, I did not realize this.
The most common "loop-the loop questions" have the cart going through the top of the loop at just the right speed so that there is no need for the track to push at all.
In those cases, The centripetal force required equals the weight force provided - and the Normal force is zero.
In this case we are told the Normal force = mg, so the net downward force is twice that of gravity alone.
Gravity pulls down with mg, the track pushes down with an extra mg, so the total force is 2mg. That means the centripetal acceleration is 19.6, not just 9.8
Since the track has diameter 46 m the radius is 23 - so you should have used 23 and 19.6 to get your answer, though coincidentally using 46 and 9.8 gave the same result.
Oh Ty it makes sense now
  • · Replies 16 ·
