New Reply
Spring/Mass System with Unequal Masses
Share Thread Thread Tools
Oct17-11, 10:15 PM   #1
I want to find the equations of motion of two masses [itex]m_1[/itex] and [itex]m_2[/itex] attached to each other by a spring on a smooth surface assuming [itex]m_2[/itex] is given an instantaneous velocity [itex]v_0[/itex] at time zero. Call the unstretched length of the spring [itex]l[/itex].
2. Relevant equations
I want to solve this using purely Newtonian methods.
3. The attempt at a solution
The position of [itex]m_1[/itex] in the center of mass frame is given by:
[tex] r_{1_{CM}} = r_1 - R_{CM} = \frac {m_2 (r_1 - r_2)}{m_1+m_2} [/tex]
Likewise, the position of [itex]m_2[/itex] in the CM frame is:
[tex] r_{2_{CM}} = r_2 - R_{CM} = \frac {m_1 (r_2 - r_1)}{m_1+m_2} [/tex]
I can write down Newton's equations for each mass using for Hooke's law [itex]r_{2_{CM}} - r_{1_{CM}} - l[/itex] as the displacement of the length of the spring from its equilibrium position.
At this point, I get two differential equations that I do not know how to solve. (Not SHM.) Can anybody help me?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct17-11, 11:14 PM   #2
The equation become SHM in the COM frame. In your notation, just make the substitution: [itex]r_{1CM} = - r_{2CM}[/itex]
Oct17-11, 11:26 PM   #3
Is that substitution justifiable even though the two masses are unequal? Certainly the distance from the center of mass to [itex]m_1[/itex] need not equal the distance from the center of mass to [itex]m_2[/itex]...
Oct17-11, 11:41 PM   #4
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
What are the differential equations you get?
Oct17-11, 11:46 PM   #5
The force on mass one will be:
[tex] F_1 = m_1 r''_{1_{CM}} = - k (r_{2_{CM}} - r_{1_{CM}} - l) [/tex]
And on mass two:
[tex] F_2 = m_2 r''_{2_{CM}} = + k (r_{2_{CM}} - r_{1_{CM}} - l) [/tex]
(Please correct me if this is wrong!)
Oct18-11, 12:08 AM   #6
Recognitions:
Two possible approaches:
1. You should be able to get an equation of the form
[tex]\frac{m_1m_2}{m_1+m_2} \ddot{r} = -kr[/tex]with an appropriate definition of r.
2. You could write your equations as single matrix equation and then diagonalize the matrix. That'll decouple the equations for you.
I know the first approach is definitely doable because it's a standard result in classical mechanics. The second one might work. I haven't worked it out, so there could be complications I'm not aware of.
New Reply
Tags
center of mass, mass, spring
Thread Tools
Similar Threads for: Spring/Mass System with Unequal Masses
Thread Forum Replies
GPE and KE of two unequal masses over pulley Introductory Physics Homework 24
Center of mass with masses of unequal widths Introductory Physics Homework 8
what happens in acompletely reversing mass-spring system? (spring turns inside out) Introductory Physics Homework 2
Effective masses of spring-mass systems Introductory Physics Homework 6
Unequal mass spring system Advanced Physics Homework 11
