Analytic functions and integration
The discussion revolves around the properties of analytic functions and their integrals, particularly focusing on the integrals of different functions along specified paths in the complex plane. The original poster presents a scenario involving semicircular paths and questions the implications of the integrals being the same despite one function not being analytic.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the implications of path independence for integrals of analytic functions versus non-analytic functions. Questions arise regarding the nature of the integrals and the conditions under which they yield the same results. There is also a discussion about the relevance of orientation in surface integrals for scalar functions.
The discussion is active, with participants questioning calculations and clarifying concepts related to analytic functions. Some guidance has been offered regarding the nature of integrals and the significance of orientation in different contexts, but there is no explicit consensus on the correctness of the initial calculations.
There is a mention of a potential mistake in calculations regarding the integrals, and the discussion includes considerations of the analytic nature of the functions involved. The participants also reference specific properties of integrals in relation to the orientation of vectors in surface integrals.
physicsjock
I have an example I want to clearify,
Let C be a semicircle from 2 to -2 which passes through 2i and let T be a semicircle from 2 to -2 which passes through -2i.
If you take the integral of z^2 dz around both paths the is the same, as the function is analytic so the integral is independent of the path,
However if you take the integral of the conjugate of z over these to paths you get
[PLAIN]http://img6.imageshack.us/img6/7467/unledpcv.jpg
[tex]e^{-it} e^{it} = e^0 = 1[/tex]
Oh okay,
So they're both i4pi, but like, what does it mean that the integrals are the same over different paths and the function is not analytic?
You're integrating the same constant from 0..pi and 0..-pi, so they are negative to each other and will cancel each other out.
"If f(z) is analytic in a simply connected region then the int from one point to another is independent of the path joining the two points in the domain."
So here f(z) isn't analytic, is the only reason the integrals are the same the trivial one?
Because zbar isn't analytic at all
No dude, I'm trying to tell you that you made a mistake in your calculation, so the integrals are NOT the same. Check your calculation please! The first integral should give 4 pi i and the second one should give -4 pi i
Oh right, phew,
Thanks man
hey could i ask a small question,
For scalar functions,
is the orientation of the normal vector relavent? the tu X tv,
where h(u,v) is the parametrization, tu tv its partial derivatives
because when you take the surface integral you take f(h(u,v))||tu X tv||dudv, so the orientation really doesn't matter right?
like for vector fields its the dot product of the two so the orientation of the vector does matter
Yes, that's correct, the orientation of tu x tv doesn't matter if the function is scalar. What matters, of course, is the relative orientation of tu and tv, but that's pretty obvious. You know that |tu x tv| du dv is the Jacobian determinant in case you have different coordinates (like cylindrical or spherical), right? In case you're dealing with a manifold, you have the Gramian determinant.
Sweet thanks a lot Leon
  • · Replies 26 ·
