How Do Protons Behave in a Magnetic Field?
The discussion revolves around the behavior of protons in a magnetic field, specifically focusing on their momentum and the angle of their velocity vector after exiting the field. The problem involves kinetic energy, magnetic forces, and the application of the Lorentz force law.
  • Participants discuss calculating the velocity of protons from kinetic energy and how to derive the y-component of momentum after exiting the magnetic field. There are questions about the application of the Lorentz force and the integration of variables to find the final velocity. Some participants express uncertainty about the correct placement of terms in equations and the process of solving for momentum.
Participants are actively engaging with the problem, offering tips and discussing various approaches to derive the necessary equations. There is a mix of understanding and confusion regarding the integration process and the relationships between the variables involved. No consensus has been reached, and multiple interpretations of the problem are being explored.
Participants are working under the assumption that relativistic effects can be ignored and are focusing on the classical mechanics involved in the motion of protons within the specified magnetic field.
nemzy
here is the question:
Protons having a kinetic energy of 8.6eV are moving in the positive x direction and enter a magnetic field B=0.0390 (k hat)T directed out of the plane of the page and extending from x=0 to x=1.08. Ignore relativistic effects
a) calculate the Y component of the protons momentum as they leave the magnetic field
Well i can find the velocity from the kinetic energy, but how can i find the momentum of the Y component when it leaves the magnetic field??
b) find the angle (alpha) b/w the initial velocity vector of the protom beam and the velocity vectr after the beam emerges from the field...
How could u find this angle? i hvae no idea
Here are some tips : suppose x-axis is horizontal, y-axis vertical and z axis points out of our paper towards us...Use the Lorentz force knowing that B = 0.039e_z and v is in the positive x direction. So F = qvB and think of what the position of F is with respect to the Y-axis. Calculate this force...this number (let's call it A) is equal to m*a and use this trick in order to calculate the velocity at x = 1.08 : a = dv/dt so you have that
F = mdv/dt = A or m*dv =A*dt and dt = dt*dx/dx and put dt*dx at the right hand side of the equation in order to come to : m*dv*dx/dt = A*dx and dx/dt = v. Finally start integrating and your problem is solved...good luck
marlon
The angle of the velocity vector after leaving the B-field can be calculating by using the Lorentz-force, calculate the velocity from this formula (as shown above) and projecting it out onto the x-axis...
marlon
so i understand how u derived this formula: m*dv*dx/dt = A*dx and dx/dt = v
so I am solving for dx/dt to find the y component right?
and A=qvB (velocity can be solved from the given kinetic energy)
and dx is just 1.08, since we are starting from an initial point of 0 to a final point of 1.08 right?
but how can i solve for dv?
well on the left hand side you will have A * m*v*dv, if you integrate this you will have
[tex]A*m*\frac{v^2}{2}[/tex]...then fill in the beginvalue of v (v_i)(calculated from the given kinetic energy) and the endvalue is just v (v_f),which is asked...
so you have then [tex]A*m*\frac{v_f ^2- v_i^2}{2}[/tex]
regards
marlon
isnt A suppose to be on the right side? hmm..this is what i got
m*dv*v= A*dx and dx/dt = v
m*((vf^2)-(vi^2))/2)* = A*dx
A*dx integrating u just get A*x and x=1.08..soo
m*((vf^2)-(vi^2))/2)* = A*x
i solve for vf, and it asks for momentum, so don't i just multiply the final velocity by the mass of the proton to find the momentum?
but i keep getting the wrong answer?
  • · Replies 37 ·
  • · Replies 31 ·
  • · Replies 16 ·
