Limiting Top Speed in Vehicles: Is Reprogramming Possible?
  • Thread starter Thread starter bhaazee
    Speed
The discussion revolves around the possibility of limiting or changing the top speed of vehicles through reprogramming the Engine Control Unit (ECU). Participants explore the technical aspects of ECU programming, the legality of such modifications, and the implications for vehicle performance and insurance.
  • Some participants suggest that the ECU can be reprogrammed to set a soft rev limit, which may involve power limiting mechanisms.
  • There is uncertainty about the programmability of the ECU, with one participant asserting that it is generally non-programmable, while others argue that it can be modified using custom maps.
  • A participant inquires whether it is possible to reset a vehicle's top speed limit from 180 km/h to 90 km/h and whether such changes can be reversed later.
  • Another participant explains that ECUs are not hardwired and can be modified since they use flash memory, allowing for changes to be made relatively easily.
  • Concerns are raised about the practicality of setting a low speed limit, suggesting it may cause issues in top gear for normally geared vehicles.
  • Questions arise regarding the legality of resetting OEM values in the ECU, particularly from an insurance perspective.
  • Some participants assert that it is legal to modify the ECU, and that lowering the top speed limit could potentially reduce insurance premiums, although this may not be guaranteed.
Participants express differing views on the programmability of the ECU and the implications of modifying speed limits. While some agree on the legality of such modifications, there is no consensus on the practical effects or insurance ramifications.
Participants note the variability in ECU designs and the potential costs associated with obtaining the necessary equipment for reprogramming. There is also mention of the lack of clarity regarding insurance policies related to modified vehicles.
This discussion may be of interest to vehicle owners considering modifications, automotive enthusiasts, and individuals involved in vehicle insurance or regulatory compliance.
bhaazee
Can anyone say me how the top speed in vehicles can be limited (changed). Is it possible to reprogram the top speed limit set by OEM?
Regards.
Not exactly sure how each manufacturer does it, but you can set a soft rev limit in top gear on the ECU, it'll do one of several power limiting things. A custom map can change these sorts of things.
"but you can set a soft rev limit in top gear on the ECU, it'll do one of several power limiting things" didn't get ur point.
But generally the Vehicle's ECU is non- programmable (I believe). This means how come a custom map can be added?
Assume my vehicle's top speed limit is 180 kmph. I want to give reset the limit to 90 kmph. Considering today's generation vehicles, can I reset the limit. May be I would change this value again later.
ECU's aren't hardwired, they are essentially flash memory with look up tables. As such they can be pretty easily changed.
In most cases setting a soft rev limit doesn't require a remap, you can plug in a laptop and some OEM (or OEM knock off) software and just type in a number. Not knowing the exact ECU, and how the ECU works means I can't give an exact answer.
Getting the right kit is prohibitively expensive for one job. Seeing the dealer or a 3rd party mapping company is your best bet.
Why on Earth do you want to set the limit so low anyway? You'll likely have trouble in top gear with that on any sensibly geared car.
Thnx. Well I just want to know whether such a change is possible. But is it legal to reset the OEM values flashed in vehicle's ECU atleast from Insurance point of view?
It's perfectly legal to do, people get maps all the time. Setting a top speed lower than the car 'as sold' from the factory should (logically) make a premium go down if the limit is done officially, it probably won't though as car insurance people are all gits. Only way to find out for sure is to ring up and ask.
Lots of company vans have it done (you see little stickers saying this van is limited to xx MPH).
  • · Replies 20 ·
  • · Replies 17 ·
21K
