Current in Series: Reasons Behind Sources Not Adding Up
  • Thread starter Thread starter amaresh92
    Current Series
The discussion centers around the behavior of current sources in series circuits, particularly why they do not add up as one might expect. Participants explore theoretical implications, analogies, and the application of Kirchhoff's laws in this context.
  • Some participants question the assumption that current sources should add in series, prompting analogies to physical forces in wires.
  • It is noted that Kirchhoff's Current Law (KCL) does not hold for current sources in series, as the current entering a node does not equal the current leaving it.
  • One participant argues that ideal current sources in series create an impossible situation, similar to ideal voltage sources in parallel, leading to contradictions in current flow.
  • Another participant emphasizes that ideal sources are theoretical and would not produce physical effects like smoke or molten metal.
  • Discussion includes the concept that KVL (Kirchhoff's Voltage Law) also fails for current sources in series due to the infinite resistance seen between them.
  • The law of conservation of energy is mentioned as a critical consideration in the discussion.
  • Humorous references to cultural figures and analogies are used to illustrate points, indicating a light-hearted approach to the theoretical discussion.
Participants express multiple competing views regarding the behavior of current sources in series, with no consensus reached on the implications or interpretations of these behaviors.
Some arguments depend on the definitions of ideal current sources and the assumptions made about their behavior in circuits. The discussion includes unresolved mathematical implications regarding infinite resistance.
amaresh92
whats the reason behind that the current sources doesn't add in series?.
advanced thanks
advanced thanks
Why would you think that they SHOULD add in series?
As a rough analogy, think of pulling on one end of a strong wire with a force F. The other end of the wire is attached to something that then feels the force F. Now make the wire twice as long by adding a wire in series with it and pull on one end with force F. What does the other end feel?
KCL at the node of two current source in series breaks down. Current into the node does not equal current out of the node. But if the current sources are in parallel, you can use KCL to add up their currents.
Really ideal current sources, connected in series, constitute an impossible situation - like ideal voltage sources connected in parallel. The two will just fight each other and produce a lot of smoke and molten metal. You can't insist on 1A flowing into one end of a wire and 2A flowing out at the other end. Where would all the charge come from to make up the difference?
Excellent point.
amaresh92, do you understand this?
Picking nits, but "ideal" sources will never cause smoke and molten metal, since they are purely theoretical.
As was said though, one of the most basic properties of series circuits, as codified in Kirchoff's Current Law, is that the current must be exactly the same through all of the components. If you think it through, it wouldn't make sense for it to be any other way, since the electrons going into and out of the line would not add up, and the cosmic account will get so pissed that you made him work through the weekend to rebalance the books he's liable to short-change you on your "metabolism" budget.
KVL also breaks for current sources in series. A current source can be viewed as having infinite source resistance. That's why when you turn off a current source, you are left with an open.
When two current sources are in series, one current source sees the other current source as a series resistor having an infinite resistance, and vice versa. As a result, a term in the KVL equation for an infinite resistance (due to one current source) will give you an infinity, since V = IR. So this is just undefined.
In other words, the first current source is forcing a constant current into an open circuit of the second current source. And the second current source is forcing a constant current into an open circuit of the first current source.
phinds said:
Excellent point.
ya got it
Yes, of course but a bit of graphics always helps in pointing out absurdities.
"" Yes, of course but a bit of graphics always helps in pointing out absurdities. ""
AMEN !
often it's a useful tool of logic to test some idea by extrapolation to its extreme.
ideal current sources in series would be an irrestible force meeting an immovable object,,
... and something's got to give
but I'm showing my age...
In terms of energy, however, heed the law of conservation of energy.
"ideal current sources in series would be an irrestible force meeting an immovable object,,
but I'm showing my age..."That was a favourite of Wilfred Pickles on Workers' Playtime. How's your memory?
That was a new name to me.
growing up in S Florida we didn't receive BBC, just some of the US midwest clear channel stations ..
found him though: http://www.britishpathe.com/record.php?id=78306
my memory ? well ,,, as another song goes...
http://www.youtube.com/watch?v=HzSaoN2LdfU&feature=player_embedded
(apology - it's not physics)
old jim
Wilfred Pickles used to have a popular daytime radio show (1950s) in which he used to interview 'ordinary people' and would ask them daft questions. One of which was "what happens when an unstoppable force meets an immoveable object?" AS none of them was academic, they couldn't give him a proper answer.
The real answer, if we use Newton's law and consider the immovable object to be of infinite mass and the unstoppable force to have infinite Newtons, is that the acceleration of the object can be any finite number.
Or something like that. It's been a few years since I had calculus class.
  • · Replies 42 ·
