Calculate the spring constant of the bungee cord
The spring constant of the bungee cord is calculated to be 36.8 N/m, based on a bungee jumper with a mass of 200.0 kg who oscillates eight times in 30 seconds and reaches a low point 20.0 m below the bridge. The formula used for the spring constant is k = (mg)/x, where m is the mass, g is the acceleration due to gravity (9.8 m/s²), and x is the displacement of the bungee cord. Additionally, the unstretched length of the bungee cord is determined to be 5.43 m using the formula L = (m + k)/k.
  • Understanding of Newton's laws of motion
  • Familiarity with oscillation and harmonic motion concepts
  • Knowledge of basic physics formulas, including kinematics and Hooke's Law
  • Ability to perform unit conversions and calculations involving mass and force
  • Study the principles of harmonic motion and oscillations in physics
  • Learn about Hooke's Law and its applications in real-world scenarios
  • Explore advanced calculations involving spring constants and energy conservation
  • Investigate safety measures and design considerations for bungee jumping equipment
Physics students, engineers involved in safety equipment design, and anyone interested in the mechanics of bungee jumping will benefit from this discussion.
physicsss
A bungee jumper with mass 200.0 kg jumps from a high bridge. After reaching his lowest point, he oscillates up and down, hitting a low point eight more times in 30 s. He finally comes to rest 20.0 m below the level of the bridge. Calculate the spring constant of the bungee cord and the unstretched length of the bungee cord.
How do I approach this problem?
Well, you know that T = 30/8 = 3.75
And [tex]T=2\cdot\pi\cdot\sqrt{\frac{m}{k}}[/tex] => k = 561.47[N/m]
You also know that 20m under the bridge a=0
[tex]\Sigma \vec{F} = 0[/tex]
[tex]mg=k\Delta L[/tex]
Now you just need to get [tex]\Delta L[/tex].
HTH
To calculate the spring constant of the bungee cord, we can use the formula k = (mg)/x, where k is the spring constant, m is the mass of the bungee jumper, g is the acceleration due to gravity (9.8 m/s^2), and x is the displacement of the bungee cord.
First, we need to calculate the displacement of the bungee cord. Since the bungee jumper reaches a low point eight more times in 30 s, we can divide 30 s by 9 to get the time for one oscillation, which is approximately 3.3 s. This means that the bungee cord oscillates 8 times in 3.3 s, so the total number of oscillations is 8 x 9 = 72.
Next, we can use the equation d = (1/2)at^2 to calculate the displacement of the bungee cord. We know that the final displacement is 20.0 m below the bridge, and the initial displacement is 0 since the bungee cord is unstretched at the beginning. So, we have:
20.0 m = (1/2)(9.8 m/s^2)(3.3 s)^2
20.0 m = 54.3 m
Now, we can substitute the values into the formula for spring constant:
k = (mg)/x
k = (200.0 kg)(9.8 m/s^2)/54.3 m
k = 36.8 N/m
Therefore, the spring constant of the bungee cord is 36.8 N/m.
To find the unstretched length of the bungee cord, we can use the formula L = (m + k)/k, where L is the unstretched length, m is the mass of the bungee jumper, and k is the spring constant.
L = (200.0 kg + 36.8 N/m)/(36.8 N/m)
L = 200.0 kg/36.8 N/m + 1
L = 5.43 m
So, the unstretched length of the bungee cord is 5.43 m.
In summary, the spring constant of the bungee cord is 36.8 N/m and the unstretched length is 5.43 m. These calculations can help ensure the safety and
11K
