What angles will allow the football to clear the crossbar?
The discussion focuses on calculating the angles at which a placekicker must kick a football to ensure it clears a 2.74-meter-high crossbar from a distance of 26.9 meters. The initial velocity of the kick is 19.8 m/s. Participants agree that the trajectory of the ball follows a parabolic path, and the calculations involve determining the horizontal and vertical components of the kick using the equations of motion. Specifically, the angles theta1 and theta2 can be found by solving a second-degree equation involving the sine function.
  • Understanding of projectile motion equations
  • Knowledge of trigonometric functions, particularly sine and cosine
  • Familiarity with the concepts of horizontal and vertical velocity components
  • Ability to solve quadratic equations
  • Study the equations of motion for projectile trajectories
  • Learn how to derive horizontal and vertical motion equations from initial velocity
  • Explore the use of trigonometric identities in projectile motion
  • Practice solving quadratic equations in the context of physics problems
Students studying physics, coaches and athletes interested in optimizing kicking techniques, and anyone involved in sports analytics or biomechanics.
terryaki
Here's a problem that I just can't seem to get. I just need to get started out.
A placekicker is about to kick a field goal. The ball is 26.9 m from the goalpost. The ball is kicked w/ a initial velocity of 19.8 m/s at an angle theta above the ground. Between what two angles, theta1 & theta2, will the ball clear the 2.74-m-high crossbar?
What am I looking for here? Do I even get the question?
This is my interpretation: What is the angle of intersection if I draw a horizontal line 2.74-m-high off the ground to the path of the ball? I'm guessing I'm going to have to use Vnaught*cos(theta). Is that what I'm supposed to figure out? If that is, how (just nudge me in the right direction)?
Just a nodge, right? I'll try. Do you agree the path of the ball will be a parabola? Think that if you kick the ball at a very small angle it will reach the goal very fast but it will also touch the ground very close to where you kicked it. It you kick it to high it will go up, get lost in the sunlight and still fall short of the goal that it might not even reach. So you must give it enough horizontal speed to reach the goal and enough vertical speed to clear the post. You're looking for the 2 solutions of a second degree equation with the variable sinθ
You are correct that the initial HORIZONTAL speed is v0 cos(theta) and the initial VERTICAL speed is v0 sin(theta).
You will need to write out the equations for height (y-component) and horizontal distance (x-component) of the football (I'll bet those are given in your book). Use the x- formula to determine the time, t, when the ball passes the goal posts. Now use the y- formula to determine the height at that time. Finally, determine what values of theta will make the height (at that time) 26.9 meters or more.
11K
  • · Replies 28 ·
9K
