Logarithm Question: Solving for x with Substitution
  • Thread starter Thread starter Doubell
    Logarithm
The discussion revolves around solving the equation √log₂x = log₂√x by substituting y = log₂x. Participants explore the implications of this substitution and the resulting algebraic manipulations.
  • Participants discuss the transformation of the original equation into a new form using the substitution y = log₂x. There is an exploration of the solutions derived from the equation y(4 - y) = 0, with some noting the omission of the y = 0 solution.
The conversation includes verification of the proposed solution x = 16, with some participants confirming its validity through substitution back into the original equation. However, there is also acknowledgment of an alternative solution x = 1 that arises from the dropped case of y = 0.
Participants note the importance of clarity in mathematical notation and communication, with suggestions for improving post formatting to enhance understanding.
Doubell
by substituting y = log2x solve for x in the following equation:
√log2x = logs2√x
logab=c then a^c = b
if y = log2x then the equation becomes √y = log2 x^1/2
this implies √y = 1/2 log2x which simplifies to √y = 1/2 y
[√y]^2 = [ 1/2 y]^2
y = (y^2)/4
4y = y^2
4y-y^2 = 0
y(4-y) = 0
4-y = 0
y = 4
if y = 4 and y = log2x then 4 = log2x
if loga b = c then a ^c = b
this implies that 2^4 = x and x = 16. anyone agrees with this solution
√log2x = logs2√x
[√y]^2 = [ 1/2 y]^2
y = (y^2)/4
4y = y^2
4y-y^2 = 0
y(4-y) = 0
4-y = 0
y = 4
Is this the equation you're supposed to be solving
[itex]\sqrt{\log_2\,x\ }=\log_2\,\sqrt{x}\ \ ?[/itex]​
The equation 2u2 = u , has two solutions. So does the equation [itex]2y=\sqrt{y}\,.[/itex]
Write 2u2 = u as 2u2 - u = 0, then factor out the common factor.
SammyS, isn't that exactly what he said he did?
Doublell, it's easy to check your answer. If x= 16 then [itex]\sqrt{x}= 4[/itex] and [itex]log_2(\sqrt{x})= log_2(4)= log_2(2^2)= 2[/itex]. Of course, [itex]log_2(16)= log_2(2^4)= 4[/itex] so [itex]\sqrt{log_2(x})= \sqrt{4}= 2[/itex] also.
Well, I admit that I didn't read his post as carefully as I should have. (I may have spent too much time working with another PH user, and some of his behaviors were contagious.) However, what I should have pointed out, is that if y(4 - y) = 0, there are two solutions for y. OP did drop the y = 0 solution.
If log2(x) = 0, then x = 1.
Writing my posts more clearly
sammys said:
well, i admit that i didn't read his post as carefully as i should have. (i may have spent too much time working with another ph user, and some of his behaviors were contagious.) however, what i should have pointed out, is that if y(4 - y) = 0, there are two solutions for y. Op did drop the y = 0 solution.
i noticed that my post are not as clear as u guys eg i write log2x when in ur posts its clear to understand any advice on how i can post my questions in a similar fashion as yours?
Please - no textspeak (e.g., u and ur). Using textspeak is a violation of forum rules.
You can write exponents and subscripts using the expanded menu that is available when you click Go Advanced. For subscripts, as in log2(x), click the X2 button and enter the subscript. (It doesn't have to be 2.)
For exponents, as in w4, click the X2 button and enter the exponent. There are a bunch of other symbols that you can use, shown to the right of the text-entry window, such as √, ≤, Ʃ, ±, and Greek letters.
mark44 said:
please - no textspeak (e.g., u and ur). Using textspeak is a violation of forum rules.
You can write exponents and subscripts using the expanded menu that is available when you click go advanced. For subscripts, as in log2(x), click the x2 button and enter the subscript. (it doesn't have to be 2.)
for exponents, as in w4, click the x2 button and enter the exponent. There are a bunch of other symbols that you can use, shown to the right of the text-entry window, such as √, ≤, Ʃ, ±, and greek letters.
thanks and i will remember no text speaking
  • · Replies 17 ·
