I don't understand what causes redox reactions to occur.
  • Thread starter Thread starter emr564
    Reactions Redox
This discussion centers on the mechanisms behind redox reactions, specifically the electron buildup on zinc when connected to copper in a high resistance voltmeter setup. It is established that zinc accumulates electrons due to its tendency to transition into an ionic form, which is thermodynamically favorable. The electrons originate from the half-reaction where zinc atoms lose electrons as they dissolve into solution, leading to a flow of electrons to copper when resistance is removed.
  • Understanding of redox reactions and their principles
  • Familiarity with electrochemical cells and half-reactions
  • Knowledge of thermodynamics in chemical reactions
  • Basic concepts of electron transfer in metals
  • Research the principles of electrochemical cells and their applications
  • Study the concept of thermodynamic favorability in chemical reactions
  • Learn about half-reactions and their role in redox processes
  • Explore the relationship between metal ion solubility and electron transfer
Chemistry students, educators, and anyone interested in understanding the fundamentals of redox reactions and electron transfer mechanisms in electrochemistry.
emr564
For example, on this website http://www.chemguide.co.uk/physical/redoxeqia/combinations.html in the second diagram from the top, it shows that *if a high resistance voltmeter is placed between two pieces of metal, zinc and copper, the zinc metal will accumulate a build up of electrons.* Then when the resistance is relieved, the electrons will necessarily flow to the copper metal, which I understand.
What I'm confused about is: why do electrons build up on the zinc metal in the first place, and where do the electrons come from?
Thank ya.
Chemistry news on Phys.org
This is exactly the same question you can ask for every chemical reaction - why does it go the way it does. Short answer is - because it is thermodynamically favorable. In most cases that means that products have lower energy than reactants (although this is oversimplification).
From the half reaction - Zn "prefers" to be in the ionic form, and some of the atoms "jump" into solution leaving their electrons in the bulk of the metal.
  • · Replies 19 ·
11K
  • · Replies 18 ·
13K
