Longitudinal waves in circuits?
The discussion centers on the nature of electrical conduction in circuits, specifically addressing the behavior of alternating current (AC) and its relationship to wave mechanics. It clarifies that while AC involves electrons moving back and forth, this does not equate to longitudinal waves in the same manner as mechanical waves. Filters in electronics operate by blocking specific frequency bands, regardless of whether the waves are longitudinal or transverse. The distinction between electric current and mechanical waves is emphasized, highlighting that they function at different levels: electron versus molecular.
  • Understanding of alternating current (AC) principles
  • Basic knowledge of wave mechanics, including longitudinal and transverse waves
  • Familiarity with electronic filters and their operation
  • Concept of frequency and its role in wave behavior
  • Research the principles of alternating current (AC) in electrical circuits
  • Learn about the differences between longitudinal and transverse waves in various media
  • Explore electronic filtering techniques and their applications in signal processing
  • Investigate the relationship between mechanical waves and electrical signals in sensors
Electrical engineers, electronics enthusiasts, students studying wave mechanics, and anyone interested in the principles of alternating current and electronic filtering.
juan avellaneda
hello
im just confusing about the electrical conduction in the electrical circuits
I mean, for example,
-an alternate voltage means that the electrons move back and forth in the circuit?
-if really this happens, then the electric waves in the circuit are LONGITUDINAL, because by definition this waves moves in the same direction that the movement
-but this led me to another question. How act a filter with longitudinal waves?
For transversal waves is easy to see it like a slot that only let pass the waves that correspond to its size. But is less intuitive for Longitudinal waves, (if such filters exists)
any help appreciated
jp
Is this a N.Tesla question?
Filters work by blocking certain frequencies or bands of frequencies, not amplitude.
Generally filters are used in electronics not wave mechanics, so for example you could have a sensors that converts an acoustic wave in a solid material(its like vibration) into an electronic signal and all waves above a certain frequency e.g 10Hz could be blocked. If the waves in the solid material were longitudinal or traverse would not matter when it is in electronic it can be filtered.
hope that clears it up for you.
Also i would not be confusing electric current/voltage with mechanical waves(ie waves in solids liguids or gasses). They are separate entities. In alternating current(AC) energy in the form of a current conducts in one direction for a set period of time, its amplitude climbing from zero to peak and back to zero, it then starts conducting in the opposite direction for the same period of time, again climbing from zero up to the peak and back to zero. So although mechanical waves look like AC electricity, its not the same thing, mechanical waves work at the molecular level while electricity works at the electron level. Not good to mix them.
John
  • · Replies 30 ·
  • · Replies 39 ·
  • · Replies 17 ·
  • · Replies 49 ·
