There are rationals between any two reals? - Rudin 1.20
  • Context: Graduate
  • Thread starter Thread starter gwsinger
The discussion revolves around the proof presented in Rudin's "Principles of Mathematical Analysis" regarding the existence of rational numbers between any two real numbers. Participants explore the implications of the Archimedean property and the conditions under which a specific integer can be chosen to demonstrate this existence.
  • One participant summarizes Rudin's proof strategy, noting the use of the Archimedean property to find an integer n such that ny - nx > 1, and questions how to ensure the existence of an integer m satisfying specific inequalities.
  • Another participant suggests that if 0 < y - x < 1, then a suitable n can be found such that 2 > n(y - x) > 1, proposing a method to identify n.
  • A participant asks for clarification on the reasoning behind the selection of m and the implications of the inequalities involved.
  • One participant proposes defining m as the infimum of a set of natural numbers greater than nx and raises questions about the properties of this set and the nature of m.
  • Another participant discusses the finite nature of integers between -m2 and m1 and suggests that if no integers satisfy the inequalities, it contradicts the established bounds.
  • Further elaboration is requested regarding the motivation behind Rudin's choice of bounds for m, questioning the necessity of including -m2 in the inequalities.
  • A later reply reiterates the use of the least upper bound of natural numbers greater than nx and the greatest lower bound of those less than nx to establish the required inequalities.
Participants express varying levels of understanding regarding the proof and its implications, with some agreeing on the use of the Archimedean property while others remain uncertain about the selection of m and the necessity of certain bounds. The discussion does not reach a consensus on these points.
Participants highlight the need for clarity on the properties of the sets involved, the existence of integers within specified bounds, and the implications of the Archimedean property. There are unresolved questions regarding the formal justification of certain claims and the necessity of specific inequalities in Rudin's proof.
gwsinger
There are rationals between any two reals? -- Rudin 1.20
In Rudin 1.20(b), Rudin proves that between any two real numbers x and y, there exists a rational number p. His strategy is to "blow up" x and y by some integer n (generated by the archimedian property) such that ny - nx > 1. Then he attempts to locate another integer m that is between nx and ny, such that m - 1 < nx < m < ny. From here we have
nx < m < ny
and when we multiply each term by (1/n) we can say that
x < m/n < y where p = m/n. Hence the proof is done.
Now my question is as follows: how can Rudin just pick an m such that m - 1 < nx < m < ny?
I certainly understand that we can use the archimedian property to find an m greater than nx, but how can we be SURE that this m is less than ny and even less than 1 unit distance greater than nx?
Here is the proof in full from the text in case it helps:
Pg 9
If x in R, y in R, and x<y, then there exists a p in Q such that x<p<y.
Proof:
Since x<y, we have y-x>0, and the archimedean property furnishes a positive integer n such that
n(y-x)>1.
Apply the archimedean property again, to obtain positive integers m1 and m2 such that m1>nx, m2>-nx. Then
-m2<nx<m1.
Hence there is an integer m ( with -m2<= m <= m1) such that
m-1 <= nx < m
If we combine these inequalities, we obtain
nx<m<= 1 + nx < ny.
Since n>0, it follows that
x < m/n < y. This proves (b) with p = m/n.
If 0< y-x<1; y-x± 0.5 , then you can always find n with 2< n(y-x)<1. The least integer N larger than 1/(y-x) will do, i.e.:
2>N(y-x)>1
Bacle I appreciate your reply but I'm afraid I don't follow. Can you elaborate a little more?
Informally, you can "see" this must be true by drawing a number line and marking the integers between -m2 and m1.
Formally, there are only a finite number of integers m between -m2 and m1 so you can "check" the inequality for each m individually. If none of them satisfy m-1 <= nx < m, you have contradicted the fact that -m2<nx<m1.
Just define
[tex]m=\inf\{a\in \mathbb{N}~\vert~nx<a\}[/tex]
Some things you need to check:
1) Why is [tex]\{a\in \mathbb{N}~\vert~nx<a\}[/tex] nonempty and bounded below? (we need that in order for the infimum to exist.
2) Why is m natural? (or equivalently, why is the inf a minimum)
3) Why is [itex]m-1\leq nx<m[/itex]
Micromass and AlphaZero thank you for your replies. The ability to show the existence of elements within certain boundaries seems to be a pretty fundamental concept in Principles of Mathematical Analysis. I tried to answer both of your questions below to help my understanding.
Micromass:
1) "Why is {a∈N | nx<a} nonempty and bounded below? (we need that in order for the infimum to exist."
Let M = {a ∈ N | nx < a}. M is non-empty because we know by the Archimedian property that for any real number there exists an integer greater than it. Since nx is a real number, we know that there is going to be an integer greater than it. Hence M is non-empty.
Furthermore, we know that M is bounded below since nx is less than any of its members (by definition).
2) "Why is m natural? (or equivalently, why is the inf a minimum)"
Intuitively, M is comprised of naturals that start at some element and expand infinitely rightward on the number line. Visually, we could see that there would be a least member of M that is less than every other member of the set (with no other lower bound greater than it) and hence the infimum. Still, how would I state this formally? I've thought for a while and can't think of how.
3) "Why is m−1 ≤ nx < m?"
We know that nx < m since m ∈ M which is the (non-empty) set of all natural numbers which are greater than nx. To show that m -1 ≤ nx we will suppose the opposite and derive a contradiction. Negating m - 1 ≤ nx is to assert that m -1 > nx (by trichotomy). First note that if m is natural (which as I stated above I haven't really formally shown to be true), m - 1 is natural provided m is greater than or equal to 1. This is true since nx is positive (two positives multiplied returns a positive by ordered field axiom #2), and m is an integer greater than nx. Specifically, consider that 0 < nx < 1 or 1 < nx. If the former than m = 1, and if the latter than m > 1. Hence m - 1 is definitely a natural. Since m - 1 is a natural greater than nx, m -1 ∈ M. Hence we have these facts
m ∈ M
m - 1 ∈ M
m -1 < m
But m is the infimum of M, meaning it is a lower bound of M. This would be an impossible if m -1 ∈ M and hence we have reached a contradiction. Thus m - 1 < nx. Hence m−1 ≤ nx < m.
AlephZero:
(1) "[Observe that] there are only a finite number of integers m between -m_2 and m_1":
First note that -m_2 and m_1 are integers (grabbed from the Archimedean property). We can say that
-m_2 < m_1 since -m_2 < nx < m_1
Hence it is true there is a finite number of integers between -m_2 and m_1 (at least 2 inclusive and at most an infinite amount).
(2) "If none of them satisfy m - 1 ≤ nx < m, you have contradicted the fact that -m_2 < nx < m_1".
This I'm unclear on. Can you elaborate this point further?
Overall, I'm really confused by Rudin chose to find the m between nx and ny such that
-m_2 ≤ m ≤ m_1
This is because the -m_2 lower bound seems completely useless since he could have just said choose the m such that
nx < m ≤ m_1
Or he could have used Micromass' method of finding the infimum of {a ∈ N: a > nx}. What's the motivation of the -m_2 at all from Rudin's perspective?
Sorry for taking so long to reply:
As others said, using the LUB L of the (non-empty ) set of natural numbers larger than nx with the least integer k greater than 1/(x-y) will do the job:
You get : nx≤ L≤ ny
You can then use the glb of all naturals that are less than nx, which will be one less than L.
  • · Replies 24 ·
  • · Replies 17 ·
18K
