| New Reply |
Work and Kinetic Energy Problem involving friction hw problem, DUE SOON |
Share Thread |
| Oct24-11, 12:27 AM | #1 |
Part 1. A(n) 2300 g block is pushed by an external force against a spring (with a 22 N/cm spring constant) until the spring is compressed by 15 cm from its uncompressed length. The compressed spring and block rests at the bottom of an incline of 32 ◦ . The acceleration of gravity is 9.8 m/s 2 . Note: The spring lies along the surface of the ramp (see figure). Assume: The ramp is frictionless. Now, the external force is rapidly removed so that the compressed spring can push up the mass. How far up the ramp (i.e., ℓ the length along the ramp) will the block move (measured from the end of the spring when the spring is uncompressed) before reversing direction and sliding back? Remember, the block is not attached to the spring. Answer in units of cm. Part 2. Repeat the first part of this question, but now assume that the ramp has a coefficient of friction of = 0.423 . Keep all other assumptions the same. Answer in units of cm 2. Relevant equations Without friction = Ui + Ki = Uf + Kf, where in this problem Ui = 1/2kx^2, Ki = 0, Uf = mgh and Kf = 0. So 1/2 kx^2 = mgh With friction = Ui + Ki + (-Fk*l) = Uf + Kf So 1/2kx^2 - mu*(mgcosθ)*l = mgh 3. The attempt at a solution I figured out Part 1. From the equation above h = kx^2/2mg l = h/sin32 Then I subtracted .15 m and converted to cm. I got the correct answer. When I tried to solve for the length with the added friction in, I first forgot to account for the length in (mu*(mgcosθ*l). I remembered to add in l, but I think I'm using the wrong l. The first l I used was .45 because that is the length of the ramp. I then tried .30 ( because .45-.15) Here is my current equation and answer but I am not sure if I chose the correct l and therefore I don't know if it is correct. Please advise. 2200 N/m *.15^2m - .423(2.3 kg * 9.8m/s^2*cos32°*.30/2*2.3kg*9.8 m/2^2 h = 1.044239263 m l = h/sinθ so: 1.044239263 m/sin32 = 1.97056294 m 1.97056294 m - .15 m = 1.821 m 1.821 m * 100 = 182.1 cm Sorry for not having a picture. |
| Oct24-11, 06:22 AM | #2 |
Recognitions:
I must say I find this "technique" of including the units with every number while you substitute most distracting [though I have seen other people doing the same], making it all but impossible to follow the calculation to see if you are doing the right thing. It is also a habit that is foreign to anything I have seen in a school or university here where I live. |
| New Reply |
Similar discussions for: Work and Kinetic Energy Problem involving friction hw problem, DUE SOON
| Problem involving spring, friction, circular motion, work, and conservation of energy | Introductory Physics Homework | 1 | ||
| Energy Problem involving Friction and Spring | Introductory Physics Homework | 3 | ||
| Problem involving kinetic friction and relative accelerations | Introductory Physics Homework | 3 | ||
| physics problem involving work done by friction | Introductory Physics Homework | 4 | ||
| Physics (mechanics) AP Problem---involving kinetic energy of a moving object | Introductory Physics Homework | 10 | ||
