Rainfall Driven Micro Hydro-Generating System
  • Thread starter Thread starter cutegaljessy
    Micro System
The discussion focuses on designing a Rainfall Driven Micro Hydro-Generating System that produces 30 W at 12 V regulated DC using a Pelton turbine. Key factors influencing power generation include the length of the water pipe, the speed of rotation of the turbine, and the flow rate of water. The power generated is calculated using the equation: Power = Head x Flow x g x Efficiency. It is established that the orientation and length of the pipe can affect both momentum and power output, necessitating careful design considerations.
  • Understanding of Pelton turbine mechanics
  • Knowledge of fluid dynamics and flow measurement techniques
  • Familiarity with electrical power calculations
  • Basic principles of hydroelectric power generation
  • Research flow measurement techniques for rainfall-driven systems
  • Explore the efficiency factors of Pelton turbines
  • Learn about the impact of pipe length and orientation on hydro power generation
  • Investigate methods to optimize head and flow for maximum power output
Engineers, renewable energy enthusiasts, and students interested in micro-hydroelectric systems and sustainable energy solutions.
cutegaljessy
Im trying to design a Rainfall Driven Micro Hydro-Generating System
Under normal operation, the generating system is expected to produce 30 W at 12 V regulated DC.
Is there any relation between the length of the water pipe, the speed of rotation of the turbine and the generated voltage?
and how to measure the flow? (Im using rainfall here)
the Power generated is equal to Head x flow x g x efficiency of the turbine
I'm using a pelton turbine, I found how the power generated is calculated
Not entirely sure what this thing is meant to look like, but I presume the length would matter as that's a distance, so with a greater distance you may lose power as it takes time for water to travel a longer distance, possible loss of momentum.
Alternatively, a longer pipe might mean increased momentum if it was vertically pointed, or on some kind of incline; depends on orientation.
  • · Replies 28 ·
