How fast do you have to heat air to create a shock wave?
The discussion revolves around the conditions necessary to create a shock wave through heating air, particularly focusing on the energy requirements and the nature of shock waves produced by explosions. It includes theoretical considerations, material limitations, and definitions related to shock waves.
  • One participant questions the amount of heat energy required to create a shock wave from a 1cm diameter heat source suspended 2m above the ground.
  • Another participant suggests that the thermal transfer function would be non-linear and raises concerns about the material's ability to withstand such heat without disintegrating.
  • A different participant shifts the focus to explosions, asking if all explosions create shock waves.
  • One participant confirms that all explosions do create shock waves and distinguishes between high and low explosives based on the speed of the shock wave produced.
  • Another participant expresses confusion about the definition of shock waves and questions whether they can exist in a vacuum, referencing a Wikipedia article for clarification.
  • One participant seeks specific information about the energy release rates of high and low explosives, asking for the weakest high explosive and the strongest low explosive in terms of joules per second.
Participants express differing views on the feasibility of creating shock waves through heating air and the conditions under which explosions produce shock waves. The discussion remains unresolved regarding the specific energy requirements for creating supersonic shock waves.
Participants note limitations related to material properties and the complexity of thermal transfer, as well as the need for experimental validation of theoretical claims.
Urza
Suppose you have a 1cm diameter heat source suspended 2m above the ground. How many watts of heat energy does it need to expend to create a shock wave?
Science news on Phys.org
It'd depend on the function of thermal transfer between the heat source and the air. I suspect this becomes very non-linear if you get to the rate of heat transfer you're talking about.
I'd also suspect that in the real world, any known material 1cm would not withstand the thermal resistance in that scenario, and, itself, ablate and explode.
Therefore, as it is a result likely only possible by experimentation, and as there are no materials to perform that experiment, I'd hazard to say the question is moot.
Ok, well since we're not imaginative enough to conceive of an object or material that can release that amount of heat without exploding then let's just consider explosions:
Do all explosions create shockwaves?
Yes. Why would you imagine an explosion not causing a shock wave? Are you thinking of 'super-sonic' shock waves?
If an explosive causes a supersonic shockwave, it is called a 'high explosive'. If the shockwave is slower than local sound, it generates a wave more like a solition, though I am unclear the difference between a solition and a sub-sonic shock wave.
I did not know exactly what a shock wave is so I checked here:
http://en.wikipedia.org/wiki/Shock_waves
I still don't know, but it's interesting reading...
it says: "...A shock wave ...is a type of propagating disturbance. Like an ordinary wave, it carries energy and can propagate through a medium (solid, liquid, gas or plasma) or in some cases in the absence of a material medium, through a field such as the electromagnetic field.
Shock waves are characterized by an abrupt, nearly discontinuous change in the characteristics of the medium.[1] Across a shock there is always an extremely rapid rise in pressure, temperature and density of the flow..."
These two statements, for example, appear inconsistent.
Can we get a shock wave in outer space...in a vacuum...sure, see the latter part of the article...how does that fit (or not) in these descriptions??
Thanks, that's actually very helpful.
Alright, I looked at High vs Low explosives, but does anyone know how much energy has to be released how quickly to create that supersonic shock wave? Maybe another way to ask that is:
What is the weakest (in terms of joules per second) high explosive known, and the strongest (once again in terms of joules per second) low explosive known?
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 23 ·
