What Units Must Coefficients Have for Maximum Particle Position Calculation?
The discussion focuses on determining the units for coefficients c and b in the equation x = ct² - bt³, where x represents the position of a particle in meters and t represents time in seconds. It is established that c must have units of meters per second squared (m/s²) and b must have units of meters per second cubed (m/s³). The maximum positive position of the particle occurs at t = 1.0 seconds, where the velocity is zero, confirming the particle's peak position. The second derivative test is recommended to verify the maximum condition.
  • Understanding of kinematics and motion equations
  • Familiarity with calculus, specifically derivatives and second derivatives
  • Knowledge of unit analysis in physics
  • Basic understanding of polynomial functions
  • Study the application of derivatives in motion analysis
  • Learn about the significance of the second derivative test in optimization problems
  • Explore unit conversion and dimensional analysis in physics
  • Investigate polynomial motion equations and their applications in real-world scenarios
Students and professionals in physics, particularly those studying mechanics, as well as educators teaching kinematics and calculus concepts.
missrikku
I don't believe that this problem is difficult, but I am unsure of myself as to the answers.
The position of the particle moving along an x-axis depends on the time according to: x = ct^2 - bt^3 (x in meters and t in seconds)
a) what units must c and b have? Let their numberical values be 3.0 and 2.0, respectively. b) At what time does the particle reach its maximum positive x position?
This is what I did:
a) m - cs^2 - bs^3 --> ms^2/2^2 - ms^3/s^3 = m - m = __ m
so, c = m/s^2 and b = m/s^3
b) x = ct^2 - bt^3
i am imagining the particle to be something like a ball thrown in the air. is this a good idea?
with that in mind, i would imagine the velocity of the ball at the max point would be 0, so:
v = x' = 6.0t - 6.0t^2 = 0 --> t=1 or t = 0
i am ruling out t = 0, because that is the starting time so i believe that the time it reaches it's max position is at 1.0 seconds.
was my process for a and b correct?
Yes, the units of b and c must be such that the "sec" cancel, leaving meters. The power on the s must be exactly the power on t
c is in "m/s^2" and b is in "m/s^3". (You do have a typo: you meant
ms^2/t^2 where you wrote "ms^2/2^2".)
Since x= ct^2+ bt^3 so x'= 2ct+ 3bt^2. As this is a physics problem, you can think "at max or min position the speed must be 0". A math major would be more inclined to think "at max or min, the derivative is 0".
Looks to might like you have it exactly right.
Hi missrikku,
I think your answer to a) is correct.
As for b): No values of b, c are given in the problem, so you should keep them as unknowns (not plug in values). Your approach of x' = 0 is IMO OK. It will give you 2 answers of t(c,b). Please check out x''(t) for your answers. If the 2nd derivative is negative, then you have found a maximum.
  • · Replies 26 ·
  • · Replies 38 ·
