Terminal Velocity: Solving a Puzzling Problem
The discussion revolves around the integration of a differential equation related to terminal velocity, specifically the expression dv/(v-vt) = -k/m (dt). Participants explore the integration process, the resulting logarithmic expressions, and the implications of constants within the equation.
  • One participant expresses confusion over the integration process and the resulting logarithmic forms, questioning how the book's answer differs from their own.
  • Another participant requests clarification on the notation, specifically the treatment of vt as a constant and the transition between lowercase and capital letters for variables.
  • A participant suggests evaluating the definite integral directly to arrive at the desired result, providing a specific integral calculation.
  • Another participant agrees with the integral evaluation but questions the necessity of factoring out a negative sign, suggesting it complicates the process unnecessarily.
  • A later reply acknowledges a mistake in their previous reasoning, realizing that their integration leads to the same result as the book's answer, but expresses embarrassment over the oversight.
  • One participant explains the rationale for factoring out the negative sign, citing the need to avoid logarithms of negative numbers when v is less than vt.
Participants exhibit a mix of agreement and disagreement, particularly regarding the integration process and the treatment of variables. Some participants agree on the final results of the integration, while others question the steps taken to arrive at those results.
There are unresolved questions about variable notation and the implications of constants in the integration process. The discussion reflects differing interpretations of the integration steps and their mathematical validity.
This discussion may be useful for individuals interested in mathematical integration techniques, particularly in the context of physics problems involving terminal velocity and differential equations.
Cyrus
looking back at a problem that puzzled the heck out of me.
integrate this: dv/(v-vt) = -k/m (dt).
The book says you get: ln ( (vt-v)/Vt ) = -k/m t
the -k/mt part is fine, because you integrate from 0 to t. The ln part is tricky though. When I integrate, I get ln(v-vt), vt is just a constant. If you do the derivative of my anwser or the books they are the same. How did the book arrive at this anwser and not mine.
Can you rewrite the problem more carefully? I don't understand how vt can be a constant if it has 'v' in it, or why a lowercase v suddenly becomes a capital V somewhere, or why v-vt suddenly becomes vt-v. Thanks.
Just evaluate the definite integral to get the desired result:
[tex]\int_{0}^{v} \frac {dv'}{v'-v_t} = -\int_{0}^{v} \frac {dv'}{v_t-v'} = \ln{(v_t-v)} - \ln{v_t} = \ln \frac {v_t-v}{v_t}[/tex]
but why even to bothing factoring out a minus sign tide? It just complicateds the integral. Its much simpler to just integrate and get ln(v-vt), no?
when you do the limits you get, ln(v-vt)-ln(v). so that's equal to ln ((v-vt)/v).
Oh my gosh. I completely poo-pooed that integral. I worked it out my way and got the same anwser. Boy do I feel like an idiot. it should work out to be,
ln(v-vt) from 0 to v, which is ln(v-vt)-ln(-vt) = to ln(1-v/vt). Thats just Embarrassing. :frown:
Cyrus,
You factor out the -1 because (a) v < vt and (b) you avoid the nastiness of dealing with logarithms of negative numbers.
  • · Replies 17 ·
12K
  • · Replies 63 ·
  • · Replies 27 ·
  • · Replies 43 ·
