What is the simplest way of selecting the last N terms of a polynomial?
  • Context: High School
  • Thread starter Thread starter kaleidoscope
    Polynomial Terms
The discussion revolves around the methods for selecting the last N terms of a polynomial, particularly in the context of the binomial expansion of (1+x)^n. Participants explore different functions and approaches to achieve this selection, with a focus on simplicity and efficiency.
  • Exploratory, Technical explanation, Debate/contested
  • One participant asks for a simpler function to select the last N terms of a polynomial, using (1+x)^6 as an example.
  • Another participant requests clarification on what is meant by "to pick" and suggests stating the question mathematically.
  • A participant proposes a function F_k that extracts the last k coefficients from a polynomial, indicating that this function could be sufficient for defining a polynomial.
  • One participant expresses that the function they are currently using is effective but wonders if a simpler version exists.
  • Another participant suggests that the method discussed is the simplest, but notes that it may be limited to polynomials expressible in the form (1+x)^n.
  • A later reply points out that the proposed method only applies to specific polynomial forms, indicating a limitation in its general applicability.
Participants express differing views on the simplicity and applicability of the proposed methods, with no consensus reached on a single best approach for all polynomial forms.
Limitations include the assumption that the polynomial can be expressed in a specific form, as well as the potential complexity of combinatorial methods that some participants wish to avoid.
kaleidoscope
If you have a polynomial like (1+x)^6 = x^6+6 x^5+15 x^4+20 x^3+15 x^2+6 x+1, What function would you use to pick only the last N terms? For instance, for N=3 pick x^6+6 x^5+15 x^4
I've being using sum of a binomial times something, but was wondering if there is anything more simple.
Thanks!
Mathematics news on Phys.org
What do you mean by "to pick"? Can you state your question mathematically?
Here:
where
for example:
tex?\dpi{150}%20(x+1)^3=\binom{3}{0}+\binom{3}{1}x+\binom{3}{2}x^2+\binom{3}{3}x^3=1+3x+3x^2+x^3.gif
^ I think he might just mean an (ordered) set of terms from the polynomial. The order is established by listing the coefficients in descending order of their degree.
I think what you want isn't so complicated. It's as follows: if [itex]p \in \mathbb{R}\left[x\right][/itex] is a polynomial with degree n, i.e. [itex]p(x) = {p_n}{x^n} + {p_{n - 1}}{x^{n - 1}} + ... + {p_1}x + p_0[/itex], define the function [itex]F_k: \mathbb{R}\left[x\right] \rightarrow \mathbb{N}^k[/itex] by [itex]{F_k}(p) = (p_n, p_{n - 1}, ..., p_{n - k})[/itex]. This "gets" the first (or if you want, last) k coefficients, which is really all you need to define a polynomial.
Black Integra said:
Here:
where
for example:
Exactly! This is the function I've being using. What I wonder is if there is a more simple version of it.
Thank you very much anyways!
I think it's the simplest way. May be, if you don't want to deal with combinatorics, use "[URL triangle[/URL]
That only works for polynomials which can be expressed in the form (1 + x)n, though ...
  • · Replies 48 ·
  • · Replies 24 ·
