Solving -1^n and (-1)^{n+1} Confusions
  • Thread starter Thread starter kdinser
The discussion centers on the confusion surrounding the evaluation of series involving terms like (-1)^n and (-1)^{n+1}. The user correctly identifies that when testing endpoints in the series \sum\frac{(-1)^{n+1}(x-5)^n}{n5^n}, factoring out -1 from (-5)^n and canceling 5^n with the denominator is incorrect. The conclusion is that \sum\frac{(-1)^{2n+1}}{n} does not represent an alternating series, as it consistently yields a negative sign, while \sum\frac{(-1)^{n+1}}{n} remains an alternating series when evaluated at x=10.
  • Understanding of series convergence tests, specifically the Ratio Test.
  • Familiarity with alternating series and their properties.
  • Knowledge of algebraic manipulation involving exponents and series terms.
  • Basic calculus concepts, particularly series expansion and convergence criteria.
  • Study the properties of alternating series and the Alternating Series Test.
  • Learn about the Ratio Test and its application in determining series convergence.
  • Explore the concept of p-series and their convergence criteria.
  • Review algebraic manipulation techniques for series, focusing on exponent rules.
Students and educators in mathematics, particularly those studying calculus and series convergence, as well as anyone seeking to clarify the behavior of alternating series.
kdinser
For the most part I seem to understand what I'm doing, but whenever you toss in a [tex](-1)^n[/tex] or a [tex](-1)^{n+1}[/tex] it starts to trip me up.
For example:
[tex]\sum\frac{(-1)^{n+1}(x-5)^n}{n5^n}[/tex]
pretty straight forward, it's centered at 5, use the ratio test and solve the inequality to obtain R = 5 with endpoints 0, 10. It's when I go to test the endpoints that I get into trouble. I am going to solve this the way I would and maybe someone can point out where I'm going wrong with my thinking or algebra.
[tex]\sum\frac{(-1)^{n+1}(0-5)^n}{n5^n}[/tex]
[tex]\sum\frac{(-1)^{n+1}(-5)^n}{n5^n}[/tex]
Just as I was typing this, I think I found my mistake, but how do I fix it?
I have been factoring out a [tex]-1[/tex] from the [tex](-5)^n[/tex] and canceling the [tex]5^n[/tex] with the one in the denominator. You can't do that can you? How about this?
[tex]\sum\frac{(-1)^{n+1}(-1)^n(5)^n}{n5^n}[/tex]
That would let the 5^n's cancel and would leave
[tex]\sum\frac{(-1)^{2n+1}}{n}[/tex]
right? Isn't this still an alternating series? The solutions manual says that when x=0 it should go to
[tex]\sum\frac{-1}{n}[/tex]
which is a divergent p series and when x = 10 it stays an alternating series.
You are right. When x=0 you get a divergent p series. But the [tex]\sum\frac{(-1)^{2n+1}}{n}[/tex] is NO alternating series because the sign always stays minus. If x = 10, you will get an alternating series : [tex]\sum\frac{(-1)^{n+1}}{n}[/tex]
regards
marlon
Thanks marlon, I see it now. No matter what n is, your always going to get -1 raised to an odd value.
  • · Replies 21 ·
  • · Replies 97 ·
