Aerodynamics and hydrodynamics
This discussion focuses on calculating the drag force on a sphere submerged in water while being towed by a boat. The drag force can be modeled using the empirical formula F_D = C_D(Re)A(1/2)ρv², where A is the frontal area, ρ is the water density, and v is the velocity. The drag coefficient (C_D) is dependent on the Reynolds number (Re), which can be calculated using Re = (ρvD)/μ, with D being the sphere's diameter and μ the dynamic viscosity of water. For Reynolds numbers less than 1, C_D can be approximated as C_D = 24/Re, while for Reynolds numbers between 1E3 and 2E5, C_D is approximately constant at 0.4.
  • Understanding of drag force calculations in fluid dynamics
  • Familiarity with Reynolds number and its significance
  • Basic knowledge of empirical formulas in physics
  • Experience using MATLAB and Simulink for modeling
  • Research the application of MATLAB for fluid dynamics simulations
  • Learn about the relationship between drag coefficient and Reynolds number
  • Explore empirical relations for drag force in different fluid scenarios
  • Investigate the effects of dynamic viscosity on drag calculations
Engineers, physics students, and anyone involved in fluid dynamics modeling, particularly those interested in practical applications of drag force calculations in water and air.
niko2000
Hi,
Let's tie a sphere, drop it into a water and trawl it with a boat. How do we calculate the angle between a vertical line and rope?
Actually I don't know much about aerodynamics and hydrodynamics so I don't know how drag force is calculated from shape, mass and speed of an object. Recently I have started using Simulink and Matlab so it would really help me to get a some formula so I could try to do some model.
Thank you,
Regards,
Niko
Well you need quite a bit of knowledge of these fields to properly do the calculations. For instance engineers usually model the drag force by using the empirical relation:
[tex]F_D=C_D(Re)A\frac{1}{2}\rho v^2[/tex]
With A the frontal surface of your sphere. rho the density of water and v your velocity. The drag coefficient ([itex]C_D[/tex]) depends on the Reynolds number so imlicitly on the velocity. If you want to find the drag force for a certain fixed velocity of the boat you could calculate the Reynolds number from its definition:<br /> <br /> [tex]Re=\frac{\rho v D}{\mu}[/tex]<br /> <br /> With D the characteristic length scale, in your case the diameter of the sphere and [itex]\mu[/tex] the dynamic viscosity of water. Next you could look up the drag coefficient in a graph or something, only for certain Reynolds numbers (<1) this can be analytically found:<br /> <br /> [tex]C_D= \frac{24}{Re}[/tex]<br /> <br /> But for Re<1 your boat would have to move very! slowly. For 1E3<Re<2E5 the drag coëfficiënt is approximately constant (~0,4). See: <a href="http://www.uh.edu/engines/spheredrag.jpg" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://www.uh.edu/engines/spheredrag.jpg</a> for an example of how to find the drag coefficient from the Reynolds number.<br /> <br /> With the drag coëfficient you can calculate the drag with the first formula. But again, I think a good calculation involves a lot of knowledge of the fields you mention and will be quite labourous, so you might still want to change your mind...[/itex][/itex]
Well, giving it another thought. If you discard the effect of the boat on the water, so you can evaluate the flow as homogeneous, a first approximation is not too difficult.
  • · Replies 49 ·
  • · Replies 20 ·
