Newton's law of cooling to find time of death
This discussion focuses on applying Newton's Law of Cooling to determine the time of death of Peter Sloane, who was found with a liver temperature of 22.26°C. The surrounding temperature was 17°C at the time of discovery, having dropped from a constant 20°C earlier in the day. The equation used is T(t) = Te + (T0 - Te)e^(-kt), with k determined as 0.0070636. The solution requires deriving a time-varying environmental temperature function and solving the corresponding ordinary differential equation (ODE).
  • Understanding of Newton's Law of Cooling
  • Familiarity with differential equations
  • Knowledge of temperature measurement and conversion
  • Ability to perform natural logarithm calculations
  • Study the derivation of Newton's Law of Cooling in non-constant environments
  • Learn how to solve ordinary differential equations (ODEs)
  • Research temperature conversion techniques and their applications in forensic science
  • Explore the implications of body temperature changes post-mortem
Forensic scientists, physics students, and anyone interested in the application of mathematical models in real-world scenarios, particularly in determining time of death using temperature data.
Lee.Robbo
URGENT! Newton's law of cooling to find time of death
The victim, Peter Sloane (a senior physics lecturer), was discovered at 9.43pm with a liver temperature of 22.26°C in the Oliver Lodge coffee room, with the window open. The temperature of the room matched that of the outside. After checking weather reports, it was found that at precisely 9.43pm, the temperature outside was 17°C, however, it had steadily been dropping by approximately 1°C every hour before this. The temperature for the rest of the day had been constant at 20°C until it started to drop. Cause of death was determined to be heavy metal poisoning. (No puns please, that's how it's stated...) Using the equation for Newton’s law (given*previously), determine how*long Peter had been dead when he was found, and consequently, his time of death.
Newton's law of Cooling:
T(t) = Te+ (T0− Te)e^−kt
Where T(t)= temperature with respect to time
Te= Temperature of surrounding environment
T0= Initial temperature (when t=0)
k= constant, worked out previously as 0.0070636
t= time
I have no idea where to start. The paper gives nothing about the initial body temperature, but even if I take that to be 37 degrees C, I'm pretty sure I can't just take natural logs, because Te isn't constant over the previous 3 hours, and it's due in tomorrow morning... Help!
Interesting problem. Essentially you want to run Newton's Law of Cooling "backwards", and with a time-varying environmental temperature, until you reach normal body temperature.
I think you'll have to write and solve a differential equation for the period where the environmental temperature is changing. Your time zero will be the moment of discovery of the body, and time increases going backwards (so the time variable represents "hours ago").
Your constant k = 0.0070636, what are the units attached to it? Seconds or hours?
What you've listed for Newton's law of cooling is actually not Newton's law of cooling. Rather, it is simply a solution of the actual law under the assumptions that ambient temperature is constant.
Newton's law of cooling is actually:
[tex]\frac{dT}{dt} = -k(T-T_e)[/tex]
In order to solve it, you'll have to derive a function for [itex]T_e = T_e(t)[/itex] using the information given in the problem, and plug this function into the equation above. You'll have to solve the ODE to obtain [itex]T(t)[/itex].
  • · Replies 17 ·
  • · Replies 41 ·
