Mathematica: NDSolve with InterpolatingFunction as initial conditions
The discussion revolves around the use of InterpolatingFunction as initial conditions in Mathematica's NDSolve for solving partial differential equations (PDEs). Participants explore the feasibility of using InterpolatingFunction, alternatives to it, and share code examples related to their attempts.
  • Some participants question whether InterpolatingFunction can be used as an initial condition in NDSolve.
  • Others suggest creating a list of values from InterpolatingFunction to use as initial conditions.
  • One participant provides an example of generating a table from an InterpolatingFunction.
  • Another participant emphasizes the need for initial conditions to be functions rather than just numbers, as the analytical form is unknown.
  • Code examples are shared, illustrating attempts to implement NDSolve with specific PDEs and initial conditions.
  • Concerns are raised about numerical instabilities in the second PDE, particularly as time approaches a certain value.
  • Participants discuss the importance of checking the stability of the differential equations and adjusting NDSolve options accordingly.
Participants express differing views on the use of InterpolatingFunction and whether it can be effectively utilized as an initial condition. There is no consensus on the best approach, and the discussion remains unresolved regarding the optimal method for implementing initial conditions in NDSolve.
Participants mention potential numerical instabilities in the PDEs being solved, particularly with respect to the settings used in NDSolve, such as MaxSteps. There are also references to the need for multiple initial and boundary conditions for the PDEs, which may not have been fully addressed in the shared code examples.
crazybird
The questions arises because I want to use the solution of one PDE as initial condition to solve another. Then using NDSolve, the first solution is given by InterpolatingFunction. I tried, it takes the whole afternoon, almost kills my computer but still not giving any result. Another computer simply refused to work after sometime, telling me memory is not enough. My question is:
1. Can InterpolatingFunction be used as an initial condition in NDSolve?
2. Is there any way to bypass InterpolatingFunction? For example, make a list of values out of InterpolatingFunction, and then solve PDE based on this list of initial conditions, just like Plot and ListPlot?
Can you post some example code? Not necessarily the whole thing you're working on, but a simplified example that contains the essence of the problem...
crazybird said:
2. Is there any way to ...make a list of values out of InterpolatingFunction...
Here is an example interpolating function and a table created from it.
In[1]:=f=Interpolation[Evaluate[Table[{x,1/x},{x,1,5}]]];
Table[f,{i,2,6}]
Out[1]= {1/2, 1/3, 1/4, 1/5, 2/15}
So long as what you plug in for your initial conditions is a number you will be fine, i.e. pre-evaluate the interpolating function before you try ndsolve (use a loop or table or something).
Hi, All, here is my example:
c = 29.979;
T = 500;
tm = -250;
σ = 100;
β=0.133427;
γ=10-5;
w=1.32949*10-8;
h=1539.06;
k=40895;
solS=NDSolve[{∂tsS[z,t]==-(γ+I β*z)sS[z,t]-I*w*aS[z,t], (∂zaS[z,t]+1/c ∂t aS[z,t])==-I*h*k sS[z,t], sS[z,-T]==0, aS[z,-T]==E^((-T-tm)2/2σ2), aS[L0,t]==E^((t-tm)2/2σ2),{sS,aS},{z,L0,L1},{t,-T,0}];
iniR=solS[[1]][[1]][[2]];
solS=NDSolve[{∂tsR[z,t]==-(γ-I β z)sR[z,t]-I*w*aR[z,t], (∂zaR[z,t]+1/c ∂t aR[z,t])==-I*h*k sR[z,t], sR[z,0]==iniR[z,0], aR[z,0]==0, aR[L0,t]==0,{sR,aR},{z,L0,L1},{t,0,T}]
FunkyDwarf: The initial condition is not just A number, it should be a function. But the analytical form of the function is unknown, because it is the solution of another PDE. See my example above.
Table[f,{i,2,6}]
Bill: Yes, one can make a list like this. But the question is how to make it into an initial condition of NDSolve?
Simon: Example is given in 5th floor.
c = 29.979;
T = 500;
tm = -250;
σ = 100;
β=0.133427;
γ=10-5;
w=1.32949*10-8;
h=1539.06;
k=40895;
You need to first get just the first one working and that code above is not usable without a lot of alterations because of the special characters in it. To post Mathematica code in here, first select it in the notebook, then do a Cell/Convert To/Raw input form. Then cut and paste the raw input form it here encolsed in code tags selected from the menu above.
Also, your first one needs six conditions, three for each function. You need the initial condition say sS(z,0)=myf(z), then the two boundary conditions like sS(-l0,t)=0 and ss(l1,t)=something else. Do that for each function.
Don't start user-defined variables with upper case letter. Can conflict with built-in functions.
Ok, then just get the first one working where Mathematica reports Interpolation functions for both the variables sS and aS, then we can work from there.
jackmell: Thanks for telling me. Well, I tried to paste but it looked ugly. I'll try more. And the first PDE indeed works, though it has only three boundary/initial conditions. I'll show later.
Working Mathematica Note:
Thanks for telling me how to insert code. Typing code directly was killing me.
Code:
\[Gamma] = 10^(-5);
T = 500;
tm = -250;
\[Sigma] = 100;
L = 1;
L0 = -(L/2);
L1 = L0 + L;
c = 29.979;
\[Omega] = 1.32949/10^8;
\[Eta] = 1539.1;
\[Mu] = 6.27;
\[Beta] = 0.1334;
k = 40895.3;
solS = NDSolve[{D[sS[z, t], t] == (-(\[Gamma] + I*\[Beta]*z))*sS[z, t] - I*\[Omega]*aS[z, t],
    D[aS[z, t], z] + (1/c)*D[aS[z, t], t] == (-I)*\[Eta]*k*sS[z, t], sS[z, -T] == 0,
    aS[z, -T] == E^(-((-T - tm)^2/(2*\[Sigma]^2))),
    aS[L0, t] == E^(-((t - tm)^2/(2*\[Sigma]^2)))}, {sS, aS}, {z, L0, L1}, {t, -T, 0},
   MaxSteps -> Infinity]
iniR = solS[[1]][[1]][[2]]
Plot3D[Re[iniR[z, t]], {z, L0, L1}, {t, -T, 0}, PlotRange -> All]
The following is the 2nd equation:
Code:
solR = NDSolve[{D[sR[z, t], t] == (-(\[Gamma] - I*\[Beta]*z))*sR[z, t] - I*\[Omega]*aR[z, t],
    D[aR[z, t], z] + (1/c)*D[aR[z, t], t] == (-I)*\[Eta]*k*sR[z, t],
    sR[z, 0] == iniR[z, 0], aR[z, 0] == 0, aR[L0, t] == 0}, {sR, aR}, {z, L0, L1},
   {t, 0, T}, MaxSteps -> Infinity]
Your code works. It's just there are numerical instabilities (or maybe the PDE itself is unstable) in the second PDE that get bad as t → T, and since you've set MaxSteps → Infinity, Mathematica keeps trying to refine the result. If you remove that option then the code runs fine.
You should check the stability of the DE and if it is meant to be stable, then maybe playing with the Method option for NDSolve and the various stepsize and precision options will give you a reasonable solution of the the time range of interest...
I've https://www.physicsforums.com/attachment.php?attachmentid=40440&stc=1&d=1319852925" to the post.
Simon: Thank you very much! It is good to know at least in principle it works in this way, though the solution is not good at all. And how do you know the instability happens at t-->T?
I'm just guessing from the plots of the numerical solution - run the code in the attached notebook. They get large and oscillatory along the z-axis as t gets large - not specifically as t → T. I'm a bit busy at the moment so I haven't actually looked closely at the PDE (it's also why it took me a while to get around to looking at your code).
Your system is two first order, linear, coupled PDEs with complex coefficients. It should be amenable to analysis, but it's not really my area of expertise and off the top of my head, I'm not sure of the best way to go about it... Sorry.
Simon: Yes, I looked at your attached notebook. Thank you very much! You already helped me a lot!
