Electric forces/static equilibrium doozy
The problem involves two identical small spheres with electric charges, suspended in static equilibrium by a fishing line. Participants are tasked with calculating the magnitude of the charges based on the forces acting on the spheres and the geometry of the setup.
  • Participants discuss the forces acting on the spheres, including the vertical and horizontal components of tension and the Coulomb force. There are attempts to derive equations relating these forces to the charges on the spheres. Some participants express uncertainty about their calculations and the expected answer.
Multiple interpretations of the problem and calculations are being explored. Some participants have provided guidance on the relationships between forces, while others question the accuracy of the given answer and the inputs used in their calculations. There is no explicit consensus on the correct charge value.
Participants note potential discrepancies in the expected answer and the calculations performed. There is mention of unit conversions and the possibility of arithmetic errors affecting the results.
etc
question:
two identical small spheres of mass 2.0 g are fastened to the ends of a 0.60 m long light, flexible, insultation fishling. The fishline is suspended by a hook in the ceiling at its exact centre. The spheres are each given an identifical electric charge. They are in static equilibrium, whith an angle of 30 degrees between the string halves and the "horizon." Calculate the magnitude of the charges of each spehere.
what I've done:
i calculated the y force necessary for each charge and i got 0.196 N. therefore i got the x charges to be 0.339 N. the distance between the two speheres is trig'd 0.5196 m. because it's in static equilibrium i figured the x charges must equal the force between the two speheres. after subbing my force into the "f=k2(q)/r^2" equation i got q to equal 5.085x10^12.
but i don't think I've got it right. can someone verify please?
etc said:
question:
The force between the two spheres is the horizontal component of the tension in the line and is provided by the coulomb force:
[tex]F_{horiz} = T_{horiz} = \frac{kQ^2}{d^2}[/tex] (1)
where d is the separation. The separation is the distance between the centers of the spheres but because they are small you can ignore their radius and have d = .60 cos(30) = .52 m.
We can measure that force because the vertical component of the tension in the fishingline supports the weight of each ball which is:
[tex]T_{vert} = m_{ball}g[/tex] (2)
Since:
[tex]T_{horiz} = T_{vert} / tan\theta[/tex] (3)
just substitute Tvert from (2) into (3). Then work out Q by substituting Thoriz = into (1).
[tex]Q^2 = T_{horiz}d^2/k[/tex]
I get
[tex]T_{vert} = 1.96 \times 10^{-2}N.[/tex]
[tex]T_{horiz} = 3.4 \times 10^{-2}N.[/tex]
[tex]Q^2 = 3.4 \times 10^{-2} \times (.52)^2/9 \times 10^9[/tex]
[tex]Q = \sqrt{1.02 \times 10^{-12}} C. = 1.01 \times 10^{-6} C.[/tex]
AM
should the final answer be to the -06 instead of -04?
if so, that's the answer i got after trying the problem another few times. but the answer that we're supposed to haveis 1.2x10^-7 C ... which really has me baffled.
Yes. I have edited the answer above.
It has me baffled too. I think the formula is correct. Just plug in the numbers. 2 grams is .002 Kg. Units in MKS. Maybe there is a mistake in the arithmetic, but i don't see it.
AM
Peace!
I did the problem twice and I had the same answer as that of A M.
Either you gave us a wrong input somewhere, or that the answer you have is not accurate...Please check the problem and the inputs in it.
I have aslo tried to solve it assuming that a charge Q was divided equally between the two charges (that is Q/2 on each ball) and did not have the answer you talk about.
hhegab
  • · Replies 32 ·
  • · Replies 31 ·
