Rate of Change of product of three functions
The discussion focuses on calculating the rate of change of the product of three functions, f(x), g(x), and h(x), at x = 1, given specific values and derivatives. The participant derived the functions as f(x) = x - 1, g(x) = (x² - 4x + 7)/2, and h(x) = -2, leading to a derivative of -4 at x = 1. The method employed involved the product rule for differentiation, confirming that the approach is valid even if the specific functions are not unique. The participant seeks clarification on the correctness of their solution and the generality of the method used.
  • Understanding of the product rule in calculus
  • Basic knowledge of derivatives and function evaluation
  • Familiarity with polynomial functions
  • Ability to perform algebraic manipulation and simplification
  • Study the product rule of differentiation in detail
  • Explore examples of differentiating products of multiple functions
  • Learn about constructing functions that meet specific derivative conditions
  • Investigate alternative methods for finding derivatives, such as logarithmic differentiation
Students in calculus, educators teaching differentiation techniques, and anyone looking to deepen their understanding of product differentiation in mathematical analysis.
tmlrlz
Find the rate of change of the product f(x)g(x)h(x) with respect to x at x =1 given that
f(1) = 0, g(1) = 2, h(1) = -2
f'(1) = 1, g'(1) = -1, h'(1) = 0
f(x), g(x), h(x) (they are not provided)
I decided to find an equation for f(x), g(x) and h(x) which satisfies all the above properties so after some guess work and a little bit of arithmetic i found that these equations will work given the conditions stated above:
f(x) = x-1
f'(x) = 1
g(x) = (x2 - 4x + 7)/2
g'(x) = x-2
h(x) = -2
h'(x) = 0
Then,
f(x)g(x)h(x) = -2(x-1)[(x2 - 4x + 7)/2)]
= (1-x)(x2 - 4x + 7)
Derivative = -1(x2 - 4x + 7) + (2x-4)(1-x)
= -x2 + 4x - 7 - 2x2 + 6x -4
= -3x2 + 10x - 11
At x = 1
Derivative = -3 + 10 - 11
= -4
I'm just not sure if this is the right way to do it because even though my functions might work, there is no way of showing how i got them because they mostly just required some thinking and its not easy to explain how you come up with the process for finding the equations. Also, I'm pretty sure there are many other formulas that would have worked and many different combinations so I'm just wondering whether i did this question properly or if there is a better way to answer this question, maybe with something more general, I'm not sure, i just want some clarification on my answer. Thank you.
Write out the derivative of f(x)g(x)h(x) symbolically by applying the product rule. You get:
f'(x)g(x)h(x) + f(x)g'(x)h(x) + ... etc. To evaluate this at x = 1, you get f'(1)g(1)h(1) + f(1)g'(1)h(1) + ... etc and you can find the numerical value of each term.
You should also get the correct answer if you invent functions that satisfy the given conditions, but it isn't necessary to deal with specific functions to do the problem.
  • · Replies 16 ·
