Cannon projectile motion problem
This discussion revolves around a projectile motion problem involving a daredevil shot from a cannon at an angle, with the goal of determining the height at which a net should be placed to catch him after traveling a specified horizontal distance.
  • Participants discuss breaking down the motion into horizontal and vertical components, using trigonometric functions to find initial velocities. They explore the relationship between time, horizontal distance, and vertical height, while questioning the application of equations of motion.
There is an ongoing exploration of the calculations involved, with some participants seeking clarification on the relationship between the horizontal and vertical motions. Guidance has been offered regarding the independence of the two motions, but no consensus has been reached on the final answer.
Participants are working within the constraints of a homework problem, and there is a focus on ensuring the correct application of physics principles without providing direct solutions.
Jameson
Insights Author
MHB
A daredevil is shot out of a cannon at 24.0° to the horizontal with an initial speed of 26.0 m/s. A net is positioned a horizontal distance of 50.0 m from the cannon. At what height above the cannon should the net be placed in order to catch the daredevil?
Ok, here's how the teacher explained it.
Vx = Vcos(theta)
Vy=Vsin(theta)
t = (horizontal distance) / Vx
and finally y = VyT + .5gt^2
So, here's the work.
Vx = 23.75
Vy = 10.575
t = 2.105
y = (10.575)(2.105) + .5(-9.8)(2.105)^2
= .54797 m
Help me
Basically this is a projectile motion problem.
In a projectile motion, the motion is split up into 2 parts - Horizontal and vertical. That's what you teacher has done here (Vcos(theta) and Vsin(Theta)).
You got to remember that the two motions are independent of each other,
so we can apply equations of motion to both.
What we have to do in this problem is :
When the dare devil has traveled 50 m horizontally, we need to find his vertical position. This is where the net is to placed, right?
So, That's all!
Yeah, I understand that the two motions are independent of each other. I just don't see how to relate them so I can get the correct answer. Can someone show me where I went wrong?
Thanks
Okay first you got that the Vi is 26 m/s, correct?
so we need to divide that into 2 components, vertical, horizontal.
so
--------/-| Vertical Vi, referred to as Vy sin 24*=26(hypo)/Vy
------/___|
-----24*---Horizontal Vi, referred to as Vx cos 24*=26(hypo)/Vx
so we got
H-|a=0---|Vix=23.75-|x=50
V-|a=-9.8|Viy=10.575|x=?
we have three things on the horizontal so we find time with x=Vit + (1/2)at^2
a=0 so we are left with 50(distance)=23.75(Vix)t
t=2.105 s
now we have 3 things on the bottom so we can solve for x with the same equation
x=10.575(2.105) - (1/2)(9.8)(2.105)^2
so we get x=.55
Doesn't, acceleration due to gravity opposes the motion?
Edit: n/m, you just moved the negative sign.
hmm i might have confused him, thanks for clarifying that. :smile:
