New Reply
static friction and kinetic friction, solve for acceleration and force.
Share Thread Thread Tools
Oct28-11, 05:22 PM   #1
A 62 kg crate is dragged across a floor by pulling on a rope attached to the crate and inclined 16° above the horizontal. (a) If the coefficient of static friction is 0.57, what minimum force magnitude is required from the rope to start the crate moving? (b) If μk = 0.31, what is the magnitude of the initial acceleration (m/s^2) of the crate?
2. Relevant equations
3. The attempt at a solution
Attempt of number (a)
fs=Fn*Ms
Let Fn + Tsin15=mg
Fn = mg - Tsin15
Attempt of number (b)
ma= Tcos15 - fk (Do I need to subtract fs in this equation?)
fs=magnitude of static friction. In this case, it's the maximum value of static friction.
Fn=normal force
T= tension of the rope
fk=magnitude of kinetic friction.
Are the equations of my attempts correct ?
How do find tension ? or is there anyway to cancel it out ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct28-11, 07:23 PM   #2
Double checked my question. No mistake.
Oct28-11, 08:01 PM   #3
Apparently, I made some mistakes on the equations above.
On the question, it states the minimum force to move the crate.
As I can imagine, at the very small instant, "the bond is broke".
Therefore, for (a), the equation would look like this
T cos 16 - fs,max = 0 (the minimum force to " break the bond")
solve for tension. (fs,max= maximum value of static friction)
Then, substitute back into the equation of the (b), to solve for acceleration.
If I make any mistake, pls correct me. Thank you.
Oct28-11, 08:11 PM   #4
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by tebes View Post
fs=Fn*Ms
Let Fn + Tsin15=mg
Fn = mg - Tsin15
This is the correct equation for Fn. But now you need an equation `in the x direction to solve for T
ma= Tcos15 - fk
correct
Once the crate starts moving, static friction no longer applies
Fn=normal force
Find it in part 'a'
Oct28-11, 08:14 PM   #5
Quote by PhanthomJay View Post
This is the correct equation for Fn. But now you need an equation `in the x direction to solve for T correct
(Do I need to subtract fs in this equation?)[/quote]Once the crate starts moving, static friction no longer applies Find it in part 'a'[/QUOTE]
Thank you. One more question, if a block is at rest, then start to move, does the force need to overcome the static friction ?
Oct28-11, 08:26 PM   #6
Recognitions:
At the max value of static friction, the block is on the verge of moving, that is, motion is imminent under the applied force . Now when you increase the tension theoretically just an infinitesimal amount above that force, the block starts to move and the kinetic friction force takes over from the staic friction force, and the crate accelerates until you reduce the tension to keep it moving at constant speed, if you so desire.
Oct28-11, 08:31 PM   #7
Once the crate starts moving, static friction no longer applies Find it in part 'a' At the max value of static friction, the block is on the verge of moving, that is, motion is imminent under the applied force . Now when you increase the tension theoretically just an infinitesimal amount above that force, the block starts to move and the kinetic friction force takes over from the staic friction force, and the crate accelerates until you reduce the tension to keep it moving at constant speed, if you so desire.
Thank you.
New Reply
Tags
acceleration, force, friction, kinetic coefficient, static
Thread Tools
Similar Threads for: static friction and kinetic friction, solve for acceleration and force.
Thread Forum Replies
Finding max acceleration up a slope with only static friction and kinetic friction Advanced Physics Homework 0
Pushing books - force, kinetic and static friction Introductory Physics Homework 11
Applied Force ,Kinetic Friction, Static Friction involving two stacked masses Introductory Physics Homework 9
Finding the force of friction acting on an object - static or kinetic friction? Introductory Physics Homework 1
Static and Kinetic Friction Forces (Finding Net Force) Introductory Physics Homework 11
