Register to reply
Potential energy and work by spring.
by Crusaderking1
Tags: energy, potential, spring, work
Share this thread:
Crusaderking1
#1
Oct30-11, 12:08 AM
P: 159
A 15.0 kg stone slides down a snow-covered hill (the figure ), leaving point A with a speed of 10.0 m/s. There is no friction on the hill between points A and B, but there is friction on the level ground at the bottom of the hill, between B and the wall. After entering the rough horizontal region, the stone travels 100m and then runs into a very long, light spring with force constant 2.50 N/m. The coefficients of kinetic and static friction between the stone and the horizontal ground are 0.20 and 0.80, respectively.
Here is the picture: http://session.masteringphysics.com/...2/YF-07-34.jpg
A) What is the speed of the stone when it reaches point B?
B) How far will the stone compress the spring?
2. Relevant equations
PE = mgh
KE = .5mv^2
spring = .5kx^2
3. The attempt at a solution
A) I did this:
PE = (15.0)(9.80)(20.0) = 2943 J
KE= .5(15.0)(10.0)^2 = 750 J
2943+750 = 3693 J
3693 = .5(15.0)(v)^2-.5(15.0)(10.0)^2
v=19.80 m/s
B) work done by spring = .5(2.50)(x)^2 = 1.25x^2
work done by friction = (0.2)(15.0)(9.8)x = 29.4x
Using quadratic:
1.25x^2 + 29.43x - 3693 = 0
x= 43.84 or -67.38
x= only 43.84 meters.
Do these answers seem right? thanks!
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
ehild
#2
Oct30-11, 02:31 AM
HW Helper
Thanks
P: 10,389
Quote Quote by Crusaderking1 View Post
A) I did this:
KE= .5(15.0)(10.0) = 750 J
2943+750 = 3693 J
v=19.80 m/s
You miss a square it the KE term: It has to be .5(15.0)(10.0)2
I do not understand what you mean with the second term when you calculate the velocity at B.
ehild
Crusaderking1
#3
Oct30-11, 11:25 AM
P: 159
Quote Quote by ehild View Post
ehild
yes, thanks. It should be .5(15.0)(10.0)^2 = 750 J.
Wouldn't the total energy = KE + PE, so 750 Joules+ 2943 joules be the total work at point B? Then set 3693 joules equal to .5mv^2-.5mvo^2, which game me 19.80 m/s.
ehild
#4
Oct30-11, 11:30 AM
HW Helper
Thanks
P: 10,389
So the total energy at B is 3693 J, what is the velocity there?
ehild
Crusaderking1
#5
Oct30-11, 11:38 AM
P: 159
ehild
Oh ok. I think that I only need to set the joules equal to the final velocity, since the initial is 0.
In that case, velocity would equal 22.2 m/s.
ehild
#6
Oct30-11, 11:55 AM
HW Helper
Thanks
P: 10,389
Correct!
Now, question B. Before the stone reaches the spring, it slides 100 m on the rough ground. So it has lost a lot of energy when reaching the spring.
ehild
Crusaderking1
#7
Oct30-11, 11:59 AM
P: 159
Correct!
ehild
thanks! I will try figure part B out now.
ok, I added work done by friction. I received (15.0)(9.8)(0.2)(100)cos180 = -2940 joules.
-2940 + 3693 joules = 653 joules.
Would the new quadratic equation be 1.25d^2 + 29.4d -653 = 0?
ehild
#8
Oct30-11, 05:46 PM
HW Helper
Thanks
P: 10,389
t
it looks all right, but the red 6 has to be 7.
ehild
Crusaderking1
#9
Oct30-11, 06:20 PM
P: 159
ehild
ah ok. good catch. Thanks a lot for the help!
Register to reply
Related Discussions
Energy Conservation & Potential Energy.. Spring/Friction Problem Introductory Physics Homework 5
Work-Energy Theorum: Spring potential energy vs Kinetic Energy Introductory Physics Homework 4
Work/Potential Energy of a Spring Advanced Physics Homework 1
Work and Potential/Kinetic Energy (spring problem) Introductory Physics Homework 2
Potential energy of a spring,POTENTIAL ENERGY OF LOADING Classical Physics 3
