Collisions in Center-of-Mass coordinates
The problem involves a one-dimensional elastic collision between two particles of different masses, specifically a particle of mass m approaching a stationary particle of mass 3m. The objective is to find the final velocities using the center of mass coordinate system.
  • The original poster attempts to apply equations related to the center of mass but expresses confusion about using conservation of momentum in a system where it is perceived to be zero. Some participants question the correctness of the initial equations and suggest writing out conservation laws explicitly.
Participants are actively engaging with the original poster's attempts, with some pointing out errors in the initial equations and clarifying misconceptions about momentum in the center of mass frame. There is a recognition of the need to clarify definitions and variables used in the discussion.
The original poster acknowledges errors in their initial post, including confusion between position and velocity vectors, and expresses uncertainty about transforming velocities back after finding them in the center of mass frame. There is an indication of missing information regarding the definitions of certain variables.
Xyius
A particle of mass m approaches a stationary particle of mass 3m. They bounce off elastically. Assume 1D. Find the final velocities using the center of mass coordinate system.
(All quantities with r or v are vectors r1 and r2 represent the vectors from the origin to each particle.)
Coordinates of the Center of mass vector.
[tex]R=\frac{m_1v_1+m_2v_2}{m_1+m_2}[/tex]
Coordinates from vector 2 to vector 1
[tex]r=r_1-r_2[/tex]
Inverse transformations
[tex]r_1=R+\frac{m_2}{m_1+m_2}[/tex]
[tex]r_2=R+\frac{m_1}{m_1+m_2}[/tex]
Those equations are from my notes/book. I applied them so..
[tex]r^{CM}_1=r_1-R[/tex]
and
[tex]r^{CM}_2=r_2-R[/tex]
I really do not know how to solve for velocities this way. It is late and maybe I am having a brain fart but how am I supposed to use the conservation of momentum relation to find velocity if it always equals zero in this coordinate system? All I have to work with is the conservation of energy. Can anyone help me out? :(??
For starters, this equation is slightly wrong:
Also,
It's not true that velocity always equals zero in the CM coordinate system. That would be inconsistent with the fact that the objects are moving relative to each other.
As a first step to solving the problem, write out the equations for conservation of momentum and conservation of energy.
Wow I must have been tired because the amount of errors in my original post is astounding! Firstly, I meant to write POSITION vectors in the R equation, not velocity vectors. Second, the inverse transformations are missing an "r" multiple after the term with the masses as well as a minus in the r2 expression. And THIRD I meant to say the MOMENTUM is equal to zero not velocity! Oh geez haha.
Anyway I know this following work is wrong because when I do it the normal way, v1f=-1/2v1i (If I remember correctly, I can't find my work from last night.)
[PLAIN]http://img511.imageshack.us/img511/9606/pfq.gif
The problem is, I can get the velocity of "v" which is the vector between r2 and r1, but I am confused on transforming it back to get v1.
I'm not sure if I'm reading your work properly - could you type it out rather than including an image? In any case, it seems like there are some variables [itex]v_i[/itex] and [itex]v_f[/itex], which I'm not clear on the meanings of, so what you're doing looks incorrect.
  • · Replies 19 ·
