For which values of x does this series converge?
  • Thread starter Thread starter moxy
    Series
The discussion revolves around the convergence of the series \(\sum_{n=1}^{\infty}{\frac{1}{(\frac{1}{x})^n + x^n}}\) for real values of \(x\). Participants explore various approaches to determine the conditions under which this series converges.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to rewrite the series and apply comparison tests, questioning whether this method captures all possible values of \(x\) for convergence. Other participants suggest comparisons for different intervals of \(x\) and discuss the implications of these comparisons.
Participants are actively exploring different methods of comparison and questioning the completeness of their approaches. Some express concerns about whether their comparisons will encompass all values of \(x\) that lead to convergence, while others provide specific examples to illustrate their reasoning.
There is an ongoing discussion about the implications of specific values of \(x\), such as \(x = \frac{1}{2}\) and \(x = 2\), and how these relate to the convergence of the series. Participants are also considering uniform convergence and the application of the M-test in their analyses.
moxy
For what real values of x does this series converge?
[tex]\sum_{n=1}^{∞}{\frac{1}{(\frac{1}{x})^n + x^n}}[/tex]
I've rewritten the series as [tex]\sum_{n=1}^{∞}{\frac{x^n}{1 + x^{2n}}}[/tex] and I know that I can make each term larger, say
[tex]{\frac{x^n}{1 + x^{2n}}} < {\frac{x^n}{x^{2n}}} = \left({\frac{x}{x^{2}}}\right)^n = \left(\frac{1}{x}\right)^n[/tex]
Then this will converge, by comparison to the geometric series, when |x| > 1. But surely this can't be a method for finding ALL values of x for which the original series converges, can it? Because I changed the series , so all I've found is the values of x for which [tex]\sum_{n=1}^{∞}{\frac{x^n}{x^{2n}}}[/tex] converges. How can I go about this in a different way?
Then there's the question of uniform convergence. Can I just use the M-test for both parts, and say that
[tex]\left|\frac{x^n}{1 + x^{2n}}\right| < \left|\frac{x^n}{x^{2n}}\right| = \left|\frac{1}{x}\right|^n = M_n[/tex]
so, [tex]\sum_{n=1}^{∞}{M_n} = \sum_{n=1}^{∞} \left|\frac{1}{x}\right|^n[/tex] converges uniformly when |x| > 1?
I just fear that I'm simplifying things too much and not getting ALL of the possible values of x such that the series converges. Any suggestions?
this problem might be well suited to a comparison
say 0<x<1, then for all n
[tex] \frac{1}{x^n} + x^n > \frac{1}{x^n}[/tex]
Hence
[tex] \frac{1}{\frac{1}{x^n} + x^n}< \frac{1}{\frac{1}{x^n}}[/tex]
note you could do similar thing for x>1 and negative values
Okay, that makes sense. But since I'm only comparing to other series, can I be sure that I'm catching all of the values of x where the original series converges?
EDIT: Nevermind...since I'm comparing the original series based on specific intervals of x, I'll be fine.
So I'll get the same interval for convergence and uniform convergence by the M-test?
not quite
consider x=1/2, using the fact below do you think the series will converge?
[tex] \frac{1}{\frac{1}{(\frac{1}{2})^n} + (\frac{1}{2})^n}< \frac{1}{\frac{1}{(\frac{1}{2})^n}}= \frac{1}{2^n}[/tex]
now consider x=2, using the fact below do you think the series will converge?
[tex] \frac{1}{\frac{1}{(2)^n} + (2)^n}< \frac{1}{2^n}[/tex]
note the symmetry in arguments, for any x>1, you can use the same argument above for y=1/x, with 0<y<1
