Solving a Probability Problem in Construction Planning
  • Thread starter Thread starter tomtk
    Probability
The discussion focuses on calculating the probability of completing a construction project within a specified duration using statistical methods. The project requires completion 7 days earlier than the mean duration of 50 days, resulting in a required duration of 43 days. The variance is given as 3.06, leading to a standard deviation of approximately 1.749. The correct Z-score calculation involves using the formula Z = (D - μ) / σ, which indicates that the probability of completing the project in 43 days is significantly low, corresponding to a Z-score of -4.001.
  • Understanding of basic probability concepts
  • Familiarity with Z-scores and standard normal distribution
  • Knowledge of variance and standard deviation calculations
  • Experience with hypothesis testing and significance levels
  • Study the calculation of Z-scores in depth
  • Learn about the standard normal distribution and its applications
  • Explore hypothesis testing at different significance levels
  • Investigate risk analysis techniques in construction planning
Students and professionals in construction planning, project managers, and anyone involved in risk analysis and statistical evaluation of project timelines.
tomtk
Hi from Melbourne.
I have a rudimentary probability question that you will probably find amusing but hopefully you can also help me!
I am studying construction planning and this question is taken from an old exam paper.
"Risk analysis: At 5% level of significance, what is the probability of completing the project at or earlier than the employer's desired duration in the question above.
The question above requires that project is completed 7 days earlier than the normal duration, μ
Where:
Mean, μ = 50
Required duration, D = 43
Variance, σ² = 3.06
Standad deviation, σ = 1.749
I assume Z = D - μ / √σ²
I thought the answer would be z=43-50/√3.06
This gives 4.001, would this mean there is a less than 1% probability of the project being completed in 43 days?
On further reading I also discovered that a 5% level of significance is the same as a 95% confidence interval? If this is the case, doesn't this make the z value 1.645? In which case none of the variables for the equation are unknown.
As you can see I have got myself very confused :
Any and all help will be greatly appreciated. I'll have this forum open all day (and night)!
tomtk said:
Hi from Melbourne.
Where:
Mean, μ = 50
Variance, σ² = 3.06
You need parentheses here.
z = (x - μ )/ σ
You need parentheses here, too, otherwise this will be interpreted as 43 - (50/√3.06
The answer to the question is not a value of z - it's the probability of completing the project at or earlier than the employer's desired duration (43 days).
Wouldn't this give you a z value of -4.001? Where are you getting a probability of 1%?
Yes.
The mean length of jobs is 50 days, with a standard deviation of 3.06 days. What fraction of jobs are done in 43 days or fewer? To answer this question look at the standard normal distribution to see how much area under the curve corresponds to your (corrected) z value.
  • · Replies 26 ·
  • · Replies 0 ·
