Calculate Weight, Mass & Density of Metal Block w/ Spring Balance
  • Thread starter Thread starter lionely
    Density
The discussion revolves around calculating the weight, mass, and density of a rectangular metal block using a spring balance. The block's dimensions and the spring's displacement are provided, along with gravitational acceleration.
  • Participants explore how to relate the spring balance reading to the weight of the block, discussing the conversion of force per unit length and its implications for calculating mass. There is also a focus on determining the volume of the block and the correct units for density.
Participants have engaged in a back-and-forth regarding the calculations, with some guidance provided on the relationship between mass and weight, as well as the formula for volume. There is an acknowledgment of potential unit conversion issues, and multiple interpretations of the volume calculation are being explored.
There is uncertainty regarding the required units for volume and density, as well as the original poster's struggle with the problem setup and calculations. Participants are also addressing the need to convert between cubic centimeters and cubic meters correctly.
lionely
1. A spring balance has a maximum reading of 10N and the length of the calibrated scale is 20cm. A rectangular metal block measuring 10cm by 3cm by 2cm is hung on the balance and stretches the spring by 15cm. Calculate
i) the weight of the block;
ii) the mass of the block;
iii) the density of the metal from which the block is made.(Assume G 10m/s^2)
I'm not sure how to attempt the question, but my friend tried to help me but he doesn't even know himself... I must do this question. :(
It's a 20 cm scale with a maximum reading of 10 N. Break this 10 N value up over the entire scale. You can use this to determine how heavy the block is.
So 10N/20cm?? = 0.5?
Okay, 0.5N/cm. If the block causes a 15cm displacement , what would that be in terms of force?
Oh ummm 0.5N/cm x 15cm = umm 7.5N?
Yes, now how do you relate the mass of a substance to its weight?
Hmmm F=ma umm considering a(g) = 10m/s^2, 7.5N = m x 10
m= 7.5/10= .75kg?
Okay, can you figure out the density now?
Yes density = mass/volume = .75kg/0.6m?
I would reconsider your volume component. Remember
[tex]V=lwh[/tex]
but the components 10 x 3x2?
Not entirely sure what units your teacher wants you to be using, but yes that is the right idea. You may be required to give your answer in cubic meters rather than cubic centimeters, though.
lol I'm stupid I converted wrongly i converted the cubic centimetres as it was centimetres I divided by 100 when I should divided by like 10^6?
Here is an easy way to do it.
V=(3/100 m)(2/100 m)(10/100 m)
Oh thank you, but I got it. I'll remember that way.
  • · Replies 23 ·
  • · Replies 30 ·
  • · Replies 32 ·
