Calculating the Catch: Solving for the Height of a Daredevil's Net
  • Thread starter Thread starter Jameson
The problem involves calculating the height at which a net should be placed to catch a daredevil shot from a cannon at an angle. The scenario includes projectile motion principles, with specific parameters such as launch angle and initial speed provided.
  • Mixed
  • Participants discuss the use of kinematic equations to determine the height of the net, with some focusing on horizontal and vertical components separately. There are attempts to clarify the correct application of gravity in the equations and the importance of distinguishing between addition and subtraction in calculations.
There are multiple interpretations and calculations being explored, with participants sharing different results and questioning the accuracy of their methods. Some guidance has been offered regarding the use of specific values for gravity and the treatment of components in projectile motion.
Participants note potential issues with rounding and the importance of initial conditions, such as the height of the cannon above the ground, which may affect the final answer. There is also mention of homework constraints and the urgency of the deadline.
Jameson
Insights Author
MHB
Somebody please! help me
I have already posted this question but no one has given me any help. I need this answer, it is due soon.
A daredevil is shot out of a cannon at 24.0° to the horizontal with an initial speed of 26.0 m/s. A net is positioned a horizontal distance of 50.0 m from the cannon. At what height above the cannon should the net be placed in order to catch the daredevil?
I know how to set it up... I think
Vx= Vcos(theta)
Vy=Vsin(theta)
x = Vxt
t = x/Vx
y = Vyt + .5gt^2
HELP ME
Nope -
y = Vyt - .5gt^2
Vy and g are in opposite directions
So you know t and you know how high the daredevil is at t
When I do that I get 43.97... which is wrong. Can you tell me what I've done wrong?
If you are using y = Vyt - .5gt^2 make sure you are using 9.80 m/s^2 for g. The minus sign accounts for what some textbooks give for gravity, 9.80 m/s^2. Only use y = Vyt + .5gt^2 when you are using -9.80 m/s^2 for gravity. Be sure not to mix them up.
z-component
I was taught Vertical components have nothing to do with horizontal components, so here is how i would solve it.
Start with a freebody diagram and then solve for time in the X-Direction
Xf = Xi +ViT + .5gT^2
T^2 = Xf - ViT / .5g
T^3 = Xf - Vi / .5g
T^3 = 50 - 26 / .5(9.8)
T^3 = 24 / 4.9
T^3 = 4.9
T = 1.7 seconds <--- Remember this
Yf = Yi +ViT +.5gT^2 G is going to equal sin(24)9.8 due to the angle launched
Yf = ViT + .5(cos(24)(9.8))T^2
Yf = (26)(1.7) + .5(cos(24)(9.8))(1.7^2)
Yf = 44.2 + 12.9
Yf = 57.1 m above the end of the cannon barrel
I'm not positive if that is correct or not, but it sounds reasonable to me
I hope that helped you understand the 2D motion
Well you added instead of subtracting. I get the surprising answer of 0.547 meter from the floor -- I would have thought it was going to be higher.
{Vyt = 10.58*2.11 = 22.26 ; .5*g*t^2= 4.9*2.11*2.11 = 21.71. If you add instead of subtract you get your answer.}
wow, those are 3 very different answers...can you explain how you got .57 meters? Because i may have showed him wrong :confused:
I don't know how you guys got either of those answers
I got 43.8
Uhh!
Xf = Xi +ViT + .5aT^2
Assume no AR, a = 0, not 9.8
I've gotten the 43.97 answer and the really small one, depending on whether you subtract or add the second part. Someone please help. It's due tomorrow!
oh..no wonder i messed up..im not sure ill have to re-work this one
Alright, I will explain how I did it.
HORIZONTAL COMPONENT
[tex]dD = 50 m[/tex]
[tex]v_o = 24cos(30) m/s[/tex]
[tex]v_f = ?[/tex]
[tex]dT = ?[/tex]
[tex]a = 0 m/s^2[/tex]
We don't care about [tex]v_f[/tex].
Solving for [tex]dT[/tex]:
[tex]dD = v_i*dT+0.5*a*dT[/tex]
[tex]50 = 26cos(24)*dT[/tex]
[tex]dT = 2.1 s[/tex]
VERTICAL COMPONENT
[tex]dD = ?[/tex]
[tex]v_i = 26sin(24) m/s[/tex]
[tex]v_f = ?[/tex]
[tex]a = -9.8 m/s^2[/tex]
Solving for dD
[tex]dD = v_i*dT + 0.5*a*dT^2[/tex]
[tex]dD = 26sin24*2.1+0.5*-9.8*2.1^2[/tex]
[tex]dD = 0.598[/tex]
is there a website your doing all that on? or how do you get that font type/style
is it me going crazy or is this a double post? :confused:
Has anyone else used LON-CAPA for homework before? I'm getting the exact same answers you guys are, but it says I'm wrong.
Im sorry but what is this LON-CAPA?
How high iis the cannon above the ground? Is that stated in the problem? If the height is H then the answer that many are getting should be incremented by H. The basic Newtonian setup has to be right.
it probably has something to do with rounding. Because if you round the time to 2.1 seconds you get .598 m, but if you don't round it at all you get 0.548. Either way, the process is right, so play around with rounding.
