How tell what Amps in a drop down volt diode
The discussion focuses on using diodes to reduce voltage from an 8.4V LiPo battery pack to below 6V for a system with multiple servos. The user inquires about the current handling capacity of diodes, specifically for a setup that may require 2 to 3 amps. It is established that using four diodes is necessary, and the current ratings can be found on the diode's datasheet. For example, the 1N4007 diode has a current rating of 1 amp, while larger diodes with a diameter of 5 mm can handle approximately 3 amps.
  • Understanding of LiPo battery specifications
  • Knowledge of diode types and their characteristics
  • Familiarity with reading electronic component datasheets
  • Basic principles of current and voltage in electronic circuits
  • Research the specifications of the 1N4007 diode and similar diodes
  • Learn about the characteristics of larger diodes suitable for higher current applications
  • Investigate voltage drop calculations in diode circuits
  • Explore alternatives to diodes for voltage regulation, such as linear regulators
Electronics hobbyists, engineers designing servo systems, and anyone working with LiPo battery packs and voltage regulation techniques.
tpczx6
Hi
I working on a 2 cell lipo pack and need to drop the volts from 8.4 to under 6 volts. I have been using diode to do this but now I need to know what amps it will handle and which diodes to use. the setup I have now runs one servo that might pull 0.25 amps but now going to a system that will be using 4 servos so I might need to be able to pull 2 or 3 amps at a given time.
Any info will help
Thanks in Advanced
T
You will need 4 diodes to do this and the current rating of these diodes is the normal current rating given in the data sheets.
So, read the number on the diode and type it into Google to get a data sheet for that diode. Then look for the current rating.
If it is a 1N4007 or similar diode, it will be about 3 mm in diameter and these have a rating of 1 amp. Larger diodes with a diameter of 5 mm have a rating of 3 amps or so.
Thanks for the info
  • · Replies 22 ·
