Push or Pull: Which is the Best Way to Move Heavy Logs with a Wheelbarrel?
  • Context: High School
  • Thread starter Thread starter ahava1017
    Pull Push
The discussion centers on the mechanics of moving heavy logs using a wheelbarrow, specifically whether it is easier to push or pull the wheelbarrow over an obstacle, such as a log blocking the path. The conversation explores the forces involved in each method and their implications for maneuverability.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant asks whether it is easier to push or pull a wheelbarrow over a log and seeks reasoning behind the answer.
  • Another participant suggests considering the vectors of the forces applied to the wheelbarrow in both scenarios, emphasizing the need to move the wheelbarrow upwards over the log.
  • A follow-up comment proposes that pulling the wheelbarrow exerts an upward force component, which may facilitate moving over the log.
  • Further, a participant describes the force vector components when pulling, indicating they are approximately equal in the horizontal and vertical directions.
  • Another participant shares personal experience, noting that a wheelbarrow with air-filled tires was easier to push over a log compared to one with hard tires, regardless of whether it was pushed or pulled.
  • A participant succinctly summarizes the difference in force application, stating that pulling involves an upward force while pushing involves a downward force.
  • A later reply expresses gratitude for the insights shared in the discussion.
The discussion presents multiple viewpoints regarding the mechanics of pushing versus pulling a wheelbarrow over an obstacle. There is no consensus on which method is definitively better, as participants highlight different factors influencing the ease of movement.
Participants mention various factors such as tire type and force vector components, but the discussion does not resolve the implications of these factors on the overall effectiveness of pushing versus pulling.
Individuals interested in mechanics, physics of forces, or practical applications of moving heavy objects may find this discussion relevant.
ahava1017
Please help me out with this question ...
While using a wheelbarrel to move heavy logs, you bump into a log laying across your path. Would it be easier to pull or push the wheelbarrel over the log blocking your path? And, why?
:smile:
Think about the vectors of the forces you apply to the wheelbarrel in each case. You need to move the wheelbarrel up and over the log. Which force vector has a component pointing upwards?
Would that be the force you're exerting upward by pulling the wheelbarrel along and then over the log?
If you are pulling it with your arms, you have approximately equal force vector components in the x and y direction, with a resultant force point at about 45 degrees between the two.
I too thought about that also while pushing my wheel barrow. Then it was noticed
my wheel barrow had small tires with air which seem to push over the log easier
then with my older wheel barrow with hard tires, I did try it by pulling the wheel
barrow over the log and used the hard rubber tire wheel barrow and the one with
the air went over easier then the hard tire in either case.
when pulling, you're pulling up
when pushing, you're pushing down
got it?
Yea I got it! Thanks so much for all of your help!
15K
  • · Replies 20 ·
