At what rate is the water leaking out of the second container?
The problem involves three containers with different shapes and a constant inflow of water. The original poster is trying to determine the rate at which water is leaking from the second container, which is conical in shape, while the water levels in all three containers are rising simultaneously.
  • Participants suggest writing volume as a function of height for each container and comparing the rates of change of volume to find when the water levels rise at the same rate.
  • Some participants discuss using specific volume equations for the containers and how to relate the inflow and outflow rates.
  • There are requests for additional hints and guidance on setting up the problem correctly.
The discussion is ongoing, with participants providing hints and partial setups for the problem. Some have shared their calculations and reasoning, while others are seeking further clarification on the approach.
The original poster has described the containers but has not provided diagrams, which may limit the clarity of the discussion. The problem also involves understanding the relationship between the shapes of the containers and their respective volumes.
ziddy83
HELP me please!
Hi, I am having trouble figuring out how to tackle this problem, it would be great if anyone can help! :eek:
Here is the problem...
The three containers shown below (sorry, i can only describe them and not draw them here, i'll describe em at the bottom) are all initially empty. Water is simultaneously poured into the containers at the constant rate of 20 cm^3/ sec. Water leaks out of a hole in the bottom of the second container at a constant rate. at some point in time, the water levels in the three containers are all rising at the same time. At what rate is the water leaking out of the second container?
Container 1: A cylinder with radius of 10cm.
Container 2: Cone shape with 60 degrees point
Container 3: Another cone with a 90 degrees point.
It would be awesome if i could get any help! THANKS!
Hint : Write V = f(h), (where V : volume, h : height) for all three containers. Find the time at which the levels rise at the same rate by comparing 1 and 3. From this determine tha leak rate of 2.
can you give me another hint?
Ok, do i set this up by using the volume equation, f(V)= 1/3 *pi *r^2* h...
this is also given in the problem..
[tex]\frac {dV_3} {dt} = 20, V_3 = 20t, and since \frac {dV_2}{dt} = r(in) - r(out) = 20 - r (out), V_2 = (20-r (out))t[/tex]
sorry i didnt include this before...but yeah, another push in the right direction would be great, thanks.
can anyone help me on this problem?
[tex]V_1 = \pi R^2 h_1 => \frac{dV_1}{dt} = \pi R^2 \frac{dh_1}{dt} = 20[/tex]
[tex]=> \frac{dh_1}{dt} = \frac {20}{100 \pi} = \frac{1}{5 \pi}[/tex]
[tex]V_3 = \frac{1}{3} \pi r_3^2 h_3[/tex]
[tex]But~\frac{r_3}{h_3} = tan 45 = \frac{1}{\sqrt{2}} => V_3 = \frac{1}{6} \pi h_3^3[/tex]
[tex]So~ \frac{dV_3}{dt} = \frac {\pi}{2} h_3^2 \frac {dh_3}{dt} = 20[/tex]
[tex]=> \frac{dh_3}{dt} = \frac {40}{\pi h_3^2}[/tex]
[tex]But~at~some~t,~ \frac{dh_3}{dt} = \frac{dh_1}{dt} = \frac{1}{5 \pi}[/tex]
From this, you can get h3, and from that, V3. Dividing V3 by 20 gives you the time in seconds. Can you take it from there ?
  • · Replies 16 ·
  • · Replies 21 ·
