New Reply
Proof of work done by an ideal gas in a quasi-static adiabatic expansion
Share Thread Thread Tools
Nov1-11, 11:38 PM   #1
Prove that the work done by an ideal gas with constant heat capacities during a quasi-static adiabatic expansion is equal to
W= (PfVf)/(Y-1)[1 - (Pi/Pf)^((Y-1)/Y)]
where Y = gamma, which is heat capacity at constant pressure over heat capacity at constant volume
2. Relevant equations
3. The attempt at a solution
Alright so this is my attempt and im not sure where to go from here...
In an adiabatic quasi-static process we can write the formula
PV^Y = constant
constant = K for simplification
Since its adiabatic no heat change so Q=0
Using the first law of thermo
Q= ΔU -W
We know that W = -PdV
and P= K/V^Y
so...
W = ΔU
W = -PdV
W = -(K/V^Y)*dV
W = -K∫(1/V^Y)*dV
W = -K[V^(1-Y)/(1-Y)]*∫dV
W = -(K/(1-Y))[Vf^(1-Y) - Vi^(1-Y)]
W = -(K/(1-Y))[Vf^(-Y)*Vf - Vi^(-Y)*Vi]
W = -(1/(1-Y))[((Vf*K)/(Vf^Y)) - ((Vi*K)/(Vi^Y))]
since Pi = K/Vi^Y and Pf = K/Vf^Y sub those in
W = -(1/(1-Y))(Vf*Pf - Vi*Pi)
Times this by (-1/-1)
and we get
W = (PfVf - PiVi)/(Y-1)
This is where I get to not sure where to go from here to make this into
Any suggestions and help would be greatly appreciative.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov2-11, 01:30 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by jrklx250s View Post
As this is an expansion, and Q=0, the work of the gas is positive. The formula results in negative work, as Pi/Pf>1 and (γ-1)/γ >0, so it should be the external work.
PV^Y = constant
Q= ΔU -W
The elementary work of gas is WG=PdV. That of an external force is -PdV. So you determine the work of the external agent.
Nice derivation!
Factor out PfVf and use that PiViγ=PfVfγ to replace Vi/Vf
by (Pf/Pi)1/γ.
ehild
New Reply
Thread Tools
Similar Threads for: Proof of work done by an ideal gas in a quasi-static adiabatic expansion
Thread Forum Replies
adiabatic expansion of real vs ideal gas Classical Physics 13
Reversible Adiabatic Expansion for an Ideal Gas Biology, Chemistry & Other Homework 1
Adiabatic expansion of an ideal gas. Introductory Physics Homework 0
Finding the work done by a gas under quasi-static, isothermal expansion Advanced Physics Homework 2
Adiabatic Expansion of an Ideal gas Introductory Physics Homework 0
