In High School chem wrong like HS Physics?
The discussion revolves around the accuracy of classical models in chemistry, particularly in relation to electron configurations, atomic radii, and the representation of energy levels. Participants explore the limitations of these classical models and consider more accurate quantum mechanical approaches, while also reflecting on their experiences in high school physics and chemistry.
  • Some participants express a desire to challenge classical models taught in honors chemistry, seeking examples that could disprove or refine these models.
  • One participant mentions the electron cloud probability model as a more accurate representation of electron behavior compared to the Bohr model, which is often taught in high school.
  • Another participant points out that while the Bohr model is useful, it does not accurately represent energy levels, as electrons in lower shells can have higher energy than those in higher shells.
  • There is a discussion about the limitations of the Schrödinger Equation, noting that it can only be solved for hydrogen-like atoms and that many electronic configurations are approximations.
  • Participants mention exceptions to Hund's rule and the octet rule, particularly in the context of lanthanides and actinides, indicating complexities in electron configurations.
  • Some participants caution against viewing Newtonian mechanics as "wrong," emphasizing its applicability in engineering and practical contexts, while acknowledging its limitations in certain scenarios.
  • There are suggestions for further reading and study, including recommendations for quantum chemistry texts to deepen understanding of the subject.
  • One participant expresses frustration about the limitations of their current understanding of quantum mechanics and seeks clarification on concepts like ionization energy and atomic radius in relation to quantum models.
Participants exhibit a mix of agreement and disagreement. While some acknowledge the limitations of classical models, others defend their utility in practical applications. The discussion remains unresolved regarding the best approach to understanding electron behavior and the transition from classical to quantum models.
Participants note that classical models serve as a foundation for understanding more complex quantum concepts, but there is uncertainty about how to effectively transition from one to the other. Limitations in the current curriculum and the complexity of quantum mechanics are acknowledged.
KingNothing
When I took physics in high school, it was prett fun partly because of the fact that there were better theories and that mainly what we were learnign was ultimately wrong.
I'm in honors chemistry now, and the class isn't giving me any trouble, however I would absolutely love it if I could come up with a few examples and/or theories that would sort of disprove what we are learning. From what we've learned (we are studying electron configurations now, atomic radii and we represent energy levels as rings around a nucleus) what we are studying is basically "classic" model of molecules. Is there anything I can bring up in class that generally is more accurate than our classic models? (i.e. relativity in physics when studying Newtonian mechanics)
Chemistry news on Phys.org
Beyond the valence model is the more accurate, but harder to visualize electron cloud probability model. The latter gives a continuously changing picture of probabilities, based on quantum mechanics, that electrons would occupy spatial points around a given nucleus. Demonstrating it, though, can often be like trying to map the positions of condensation within a three-dimensional weather cloud on a two-dimensional page.
Ah, so you want to one-up your teacher, eh ? :wink:
You are only being taught something that's roughly equivalent to the Bohr model for the atom. According to what you're learning, levels (or shells) of higher energy are farther away from the nucleus. So, it would seem to make sense that all the electrons in the n=4 shell have more energy than those in the n=3 shell. But this is not true. So, in fact, there are some electrons in the 3rd shell that are at a higher energy the some of the electrons in the 4th. Within shells, there are things called orbitals, and these orbitals have different shapes.
For a more accurate understanding of the behavior of electrons in an atom, one must solve what is known as the Schrödinger Equation (which is a technique of Quantum Mechanics). But really, the Bohr model does surprisingly well for things like atomic spectra.
In HS all you need is the Bohr model, it should work just fine. Although solving the Schrödinger equation will tell you everything there is to know about that system, it can only be solved for the hydrogen and hydrogen like atoms nothing more. There are still over 100 elements left that the Schrödinger equation must be solved for. The electronic congifigurations you are learning 1s2 2s2 etc... are merely approximations since the Schrödinger equation can not be solved for an atom with more than 1 electron.
Its not really that major, but Hund's rule fails for the Lanthanides and Actinides, due to complications in the electron picture described by previous posters. In other words, the configuration for Cerium (atomic # 58) is [Xe] 4f1 5d1 6s2 and not [Xe] 5d2 6s2 as one might expect - the 4f1 electron is a lower energy state than the 5d2 electron.
There are many exceptions to the octet rule - particularly with sulfur and phosphorus. And it doesn't really make much sense metal compounds (alloys)
I want to emphasize that, if what you meant by "wrong" is the Newtonian mechanics, then you are incorrect. If you think Newtonian mechanics are wrong, then you should quickly evacuate the building you are in, because it was constructed by structural engineers who used Newtonian mechanics.
Let's get this very clear: Newtonian mechanics is NOT wrong. It just has a region of applicability. We know when we can safely use it, and we know when we can't. In fact, anyone who thinks we should use SR or QM to construct a house is a menace to society and should be quickly institutionalized.
Zz.
Be patient, those models you are studying now are inaccurate but will help you to understand "pure quantum" chemistry methods. Anyway, if you can´t stop your curiosity, congratulatins!. I recommend you Ira Levine´s Quantum Chemistry (with another book of introduction to QM that you choose). Wellcome!
Zz.
Yes, yes, I'm aware that it's 'less accurate' a.k.a. 'region of applicability' a.k.a. 'region of wrongness'...however you want to say it. I know that even less accurate theories have their place. I knew that before. Sorry if you were mislead by the title.
Anyway, back to chemistry. We talked in class about ionization energy, reactivity, and atomic radiuses and how they relate to the electron configuration. Like for example, my teacher explained that elements' ionization energy varies with the atomic radius because if the radius is greater, then the valence electrons are farther from the nucleus and thus require less power to be pulled away...or something to that effect. How would something like that be explained with quantum mechanics?
In my head I'm kinda thinking about how to convert the Bohr model to QM model, and so far I just kinda take electrons and throw them in a big cloud where they move around like minnows in a bucket...but how do I incorporate something like a valence shell or an atomic radius?
You can't try to understand QM at this level. Just be patient and you'll learn some of in it college.
wait until uni / college and it really all becomes clear...
Study the shapes of the suborbitals, their orientations, size, and distance from the nucleus, these are somewhat related to the positional probability and you can more skillfully understand such concepts as you mentioned. This will be more applicable when you enter organic chemistry (which hybrid orbital sp3, sp2, sp, offers more stability for its anion, using the factors I mentioned in the beginning of this post? etc...)
KingNothing said:
When I took physics in high school, it was prett fun partly because of the fact that there were better theories and that mainly what we were learnign was ultimately wrong...
I'm curious about what you studied in physics that was wrong. If it really was, then teachers, parents and students need to raise a stink with the company that publishes that text, and the school for adopting it.
Even some leading philosophers have contended that all theories are ultimately wrong.
If/when someone disproves the theory of atoms/molecules ect i'll be there to laugh. But then i'll probably stop, since it would ultimately ruin the world. Can you imagine what it would be like if that happened? Almost everything we know would be wrong...
That would be a bit of a trip heh
Jordan Veale
With the sad state of affairs in the world today, maybe it would be best of some people learned they were wrong all along...
... and yet you (and them) do not see the irony in THAT theory.
Zz.
ZapperZ,
I said it was a contention, not a theory. I also mentioned that this is true ultimately, not necessarily now. No doubt our statements, like any other, are vulnerable to paradox in their finiteness. I'm sorry to have steered off onto the path to philosophy.
Up_Creek,
There are realists, among them Bas C. van Fraassen I believe, who propound that atoms are theoretical, not real, entities, because they are not directly observable. I'm no expert in the subject, though.
Loren Booda said:
Up_Creek,
Man! You weren't kidding when you said "No doubt our statements, like any other, are vulnerable to paradox in their finiteness.". Right after you felt sorry for "steering" this thread into philosophy, you immediately turn around and contradict yourself.
$10 says that this "Bas C. van Fraassen" has never done a single experimental physics measurement on an "atom". And yet, he has managed to sucker enough people to actually pay MORE attention to his ignorant statements than what ALL of physics has to say.
Zz.
Far from doing any experiments, he doesn't even have a degree in physics.
From his website
I was born in Goes, the Netherlands, 5 Ap 1941, and emigrated with my family to Canada in 1956. I attended the University of Alberta (B.A. (hon.), Philosophy, 1963), and the University of Pittsburgh (M.A. 1964; Ph. D., Philosophy, 1966).
But he seems to be a fairly reputed philosopher so I doubt he'd actually say that atoms "are not directly observable".
Below is an STM picture of xenon atoms on a nickel (100) plane measured by Eigler at the IBM Almaden labs :
http://www.almaden.ibm.com/vis/stm/images/stm10.jpg
Not only have the atoms been imaged, they were actually moved into the specific locations using an STM tip.
For more pictures, check out the picture gallery at their website
And recently, Rugar's group at IBM detected a single electron spin using MRFM.
<just pre-empting anyone that might want to say that electrons are not directly observable>
van Fraassen, whom I may have previously misrepresented, says more along the lines that atoms are theoretical entities because they cannot be observed directly by the senses.
I hope I honored what Up_Creek had said, however, previous to my post.
If you think van Fraassen a kook, start a thread on him in the Philosophy forum.
Anyone here done experiments on individual atoms? The closest I came were a Millikan oil-drop experiment with e/m to 1% of accepted value and using a 1 MeV van de Graaf generator to replicate Rutherford's experiment.
That doesn't make it better. In fact, it is quite sad. It reveals even a greater level of ignorance. But I expect nothing less...
No, I'll let other people frolick in there with their own "theoretical entities". Now talk about ideas that are not directly observed!
Zz.
That may be what he says, but no one with any understanding of the philosophy of science should take that argument as having any meaning at all. He should brush up on this topic.
ZapperZ,
I suggest you explore your need to carry out ad hominem attacks on Physics Forums, since none of us is truly an expert in the field.
Loren Booda said:
ZapperZ,
And similarly, I would suggest you confine your philosophical musings to the Philosophy section, and this meandering off the topic would NOT have happened in the first place.
Zz.
Alright kids, stop fighting and sit back down. I think philosophy has its place in physics (philosophy was why einstein diverged from the beliefs at the time, not hard facts), however I don't think that place for philosophy is in this thread.
Does anyone have anything more to add to the original question? I'm a junior in high school, so I can probably take on some college chemistry/physics without much difficulty.
Higher atomic numbers tend to involve greater relativistic effects, usually not considered in basic chemistry.
The properties of water and carbon, explored in biochemistry, are quite unique and lead to the bases of life. A biochemist here might be able to help you further in that regard.
So sorry for developing the science, Mr KingNothing!
Correction: greater electronic relativistic effects.
I found this website which does detail some of the misconceptions HS students acquire from textbooks and teachers:
http://www.rod.beavon.clara.net/chemistry_contents.htm
Among them:
Q10 is not 2; an exploration of the fiction that reaction rates double for a 10K rise in temperature
The real pH of H2SO4
As well as interesting articles such as:
Chemists' decline?
What is a syllabus for?
Does anyone else know of websites debunking popular science misconceptions?
  • · Replies 20 ·
  • · Replies 102 ·
11K
  • · Replies 18 ·
