New Reply
Normal frequencies and normal modes of a multi-part system
Share Thread
Nov2-11, 09:30 PM   #1
***This is problem 11.29 in Taylor's Classical Mechanics***
A thin rod of length 2b and mass m is suspended by its two ends with two identical vertical springs (force constant k) that are attached to the horizontal ceiling. Assuming that the whole system is constrained to move in just the one vertical plane, find the normal frequencies and normal modes of small oscillations. [Hint: It is crucial to make a wise choice of generalized coordinates. One possibility would be r, φ, and [itex]\alpha[/itex], where r and φ specify the position of the rod's CM relative to an origin half way between the springs on the ceiling, and [itex]\alpha[/itex] is the angle of tilt of the rod. Be careful when writing down the potential energy.)
2. Relevant equations
3. The attempt at a solution
Right now, I'm just trying to set up the Lagrangian for this system, but the potential is giving me some problems. I recognize that there is a gravitational potential and a spring potential. I'm attempting to find the positions of the ends of the rod relative to some fixed point; however, I'm not sure what fixed point I should choose. Ultimately, I'm trying to find the lengths of the springs in terms of r, φ, and [itex]\alpha[/itex]. I'm getting a little frustrated with the trig and trying things out. Could someone point me in the right direction?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov3-11, 03:31 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Using the suggested coordinate system, write down the (xR, yR) coordinates of the right end of the rod. The top of the right spring is located at (b, 0). The distance between those two points is the length of the right spring. You can do the same thing for the left spring with the top end connected to the ceiling at (-b, 0).
New Reply
Similar discussions for: Normal frequencies and normal modes of a multi-part system
Thread Forum Replies
Finding frequencies of normal modes with the systematic method Introductory Physics Homework 0
trimolecular system (normal modes) Atomic, Solid State, Comp. Physics 1
Normal Modes Introductory Physics Homework 22
Normal Modes Classical Physics 7
Normal modes Introductory Physics Homework 3
